SOURCE: Sony KDF - 50E2000 Projection TV Lost Brightness control after replaceing bulb
Let me know have you adjusted Lamp Replacement option in Menu > Settings in TV?
SOURCE: REAR PROJECTION TV SCREEN GETTING HARD TO SEE
Your TV requires service and cleaning of screen, mirror and 3 lenses (of CRTs) as looks dusty.
Below is an exploded view how to take off front beznet assembly of this TV to clean inside with moist cotton cloth.
Unplug TV before taking off front of TV.
SOURCE: Sony Wega KF-42E200A Projection Bulb
New bulb is just fine.
3 blink shows that lamp cover after replacement of bulb in TV is not fixed properly or not seated well in its position.
Put new bulb and carefully place back lamp cover in its position because lamp cover will press tinny safety switch inside that will send signal to system control of TV that lamp is installed properly.
Turn On TV and get vivid picture of Sony.
Thanks.
SOURCE: Sony - KP61XBR48. I need to know a model of the replacement Lamp
First of all, there are no lamps inside this set, there are CRTs. These are not just replaced as lamps would be. The CRTs themselves will run at leas $80 each. To change these will require replacing the coolant for the CRT as well which is not a DYI type of job. The coolant is dangerous and needs to be handled carefully. Also, once a CRT is replaced, a complete mechanical and electronic convergence adjustment must be made. There is a specific order in which to do this that is outlined in the service manual and it requires a template that would need to be purchased as well.
Unless there is a specific problem that needs to be addressed, it is unlikely that any of the CRTs needs to be replaced.
If you are having a problem with the set, can you please update this with a description of the problem? We should be able to assist in the resulution of the problem with something less drastic than CRT replacement.
Thanks,
Dan
Testimonial: "Very informative and fast reply"
