HP NetRAID-2M SCSI Controller Logo
Posted on Sep 02, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Raid degraded when I ran an old diagnostic (1999) it said failed to spin up. This is a 5 set striped set. The server is still working (though I don't know why). Is there a diagnostic for windows that can let me know which of the five drives are having the problem? The best guess model number is hp netraid adapter D.03.02. that is what comes up on the command line during POST
Robert A. Watson
Level 3:
  • Master 774 Answers
  • Posted on Sep 02, 2017
Robert A. Watson
Master
Level 3:
Answers
774
Questions
0
Helped
303249
Points
2079
If you are running a Intel processor, please go to the Intel site and use their free scan for Intel drivers utility. Install an updated RAID controller and then try to sort out the issue using Device Mgr.
5 Related Answers
Anonymous
  • 47 Answers
  • Posted on Mar 11, 2008
SOURCE: raid config problem
download a driver over the net
Anonymous
  • 3614 Answers
  • Posted on Jul 25, 2008
SOURCE: ugrade of DL380 G4 Server HDD Raid Array 36GB --->146GB Required
Try to look at this Guide & Manual on "HOW TO"
Just let me know..
Hope my initial idea/info helps you..
Thanks,
micro
Anonymous
  • 91 Answers
  • Posted on Jun 18, 2009
SOURCE: I can't make the SCSI raid matrix on my Hp XW8200 to work
what about the cable connection is it one?
Mark Dewar
  • 107 Answers
  • Posted on Jul 09, 2009
SOURCE: I have a hp elitebook 2730p with Vista Ultimate
Have you run a hard drive testing program? I would think that it is likely that the hard drive has gone bad
bhaughee
Bill Haughee
  • 17 Answers
  • Posted on Aug 02, 2009
SOURCE: server does not recognize new drive installed to
what controller (may want to boot controller bios to format drive)
A disk read error has occurred when booting a Dell PowerEdge 2950. Passes all diagnostics. Will run chkdsk from CD. Raid battery was degraded at last reboot but all disks showed to be fine. Raid 1
what OS?
what disk?
no raid card stated, no array stated, no type of array stated.
One can put 100s of RAID cards in this server.
both raid cards or HBA cards,(forJBOD)
i can fix any server, but first need to know what is in the box first
you meant the boot disk has errors, right,? boot.
that would tell me the disk IS BAD.
but if and ARRAY , that means you must run SMART tests
on the disks, 1 by 1 to find the bad disk.
if smart shows its bad, or weak its for sure BAD.
on real servers. the server sends you email, (set up right)
telling you disk 3 in a RAID 6 is bad, replace it now.
are you running hardware or software raid, or HBA or
fake raid cards, (4 classes there.!)
the base system new has.
4 port SAS 5/i integrated SAS controller (no RAID_
and optional, from DELL , news.
Optional PERC 5/i integrated SAS/SATA daughtercard controller with 256MB cache,
PERC 4e/DC, PERC 5/e adapter
or any of 1000s of other aftermarket cards there.
I run LSI 9361s (with MSM appl loaded)
this card will tell you what disk failed every time no kidding.
so will the PERCs setup correctly
the PERCs and my LSI and my HP raids
all have installed monitors for the RAID ,a program that runs full time all the time, and reports errors , many ways,
did you load that first and use it? seems not.
as no mention of SMART at all.
good luck.
Im not sure the names on DELL , MSM like software.
ah its OSA
never run a PERC lacking this APP. or you can not keep the server on line,.
http://www.dell.com/support/search/us/en/04#q=Dell%20OpenManage%20Server%20Administrator&sort=relevancy&f:langFacet=[en]
tip
FAIL-SAFE FILE SERVER AND COMPUTER SYSTEMS If your data is very important, you...
If your data is very important, you should consider doing regular data backups because hard disk will fail at some at some stage in the future. This is especially true when you get an error message"hard drive is about to fail".
Depending upon how critical your computer or files server to you or your business, you should consider building a fail-safe computer or file server system using RAID technology. RAID means "A Redundant Array of Inexpensive Disks" and there are several levels of RAID.
For details of different RAID levels - click on this link -
http://searchstorage.techtarget.com/sDefinition/0,,sid5_gci214332,00.html
The most common of the fault redundant RAID systems are -
RAID 0 + RAID 1 provides fastest data transfer Mirrored hard drives.
RAID 5 is one of the most popular system, it data striping across hard drives with error correction. It has excellent performance with fail-safe system and allows for hot swappable hard drives.
There should be redundant powers supply inside the computer or file server in the event of a power supply failing.
Another consideration is to install a UPS (uninterruptible power supply) to prevent a computer or server shut down from power outages, as this will corrupt your data.
These systems do not mean you should not back up your data on a regular basis.
on Oct 20, 2010 • Computers & Internet
How to save a raid0 disk
Raid O is no RAID. Data is lost if the hard drive failed. Always use RAID 1 (mirrored) for OS and RAID 5 (striped) for DATA. That's 5 drives your server should shave been configured with.
I dont want mirroring
Use RAID 1 (Striped) or RAID 5 (Striped w/Parity) Please consult your RAID hardware documents for information on configuring RAID.
Good Luck
C2Solutions
1helpful
Dell poweredge t110 Raid 5 setup on PERC 100 raid config in bios stating Virtual drive degraded and drive 2 is in ready state...how do we remove from drive array and install a new on without data loss
In a RAID 5 config, you need at least 3 drives (you can have more however). A small part of every drive is then reserved for recovery data for the other drives. So two drives together hold all the data needed to restore a 3rd drive.
The Raid Controllers in the Dell Poweredge Servers are hot swappable. So you can just pull the faulty disk and then insert a new replacement drive in the same slot (Needs to be the same type and size or bigger. However, if the disk is bigger than the other 2, then only the size of the two other disks will be used on the new drive). The Raid controller will then see that there is a new disk and automatically start the recovery process. You will be able to see this when you open the Controller software. Once the recovery is done, the RAID 5 will be fully functional again.
While one of the disks is faulty or missing the two remaining disks will continue to work, but at the severely degraded performance. After the rebuild the performance will be back to the way it was before.
The rebuild can take more than an hour, depending on the disk sizes used.
There is also an option on some Controllers to select one drive as a "spare". Then you insert one more disk and set it as spare. It will not start working unless one of the other disks in the Raid fails. That's when it is used automatically as a replacement.
PowerEdge 4200 RAID 5 - 2 out of 4 failed. Getting "Operating System Not found". Option replace 1 drive of the two that failed. Option 2 replace both drives. Option 3 send all 4 drives for...
If two drives have failed out of a RAID 5 array, unfortunately i'm pretty sure that means that the array has degraded beyond its redundancy level.
Advanced data recovery may be able to help with getting your data back, but I wouldn't pin your hopes on it. Once two discs fail, the array becomes degraded, and the data is irrecoverable.
Did you manage to make a backup before the drive(s) died?
Backup slow
You don't specify whether previously on your USB it was the same lacie external or whether it was a different external drive. It sounds like you were using a different external drive, most likely a single drive.
You've specified that you've got your lacie setup in raid 5. Raid 5 gives a very good read spead and a good redundancy for incase a drive fails, however it's write speed is very very slow.
It will be much slower than a single drive on USB for writing to it (i.e. backups), but you should see a huge performance boost in reading from the drive than your previous usb.
If you need it to be faster, you would be better suited looking at configuring it for one of the following raid setups:
Raid 0: striping (not recommended for backups) - data is split over all drives, however if 1 drive fails you lose all data.
Raid 10: striping + mirror . half the drives are striped (like above), but the other half mirror the striping half so if one drive fails there's a backup of it. You only get half the disk space though, so if you have 4 x 1Tb drives, then you'll only get 2Tb of space.
How to add new HD in existing RAID 5
Here is a link to info from Dell about exactly how to do it.
http://en.community.dell.com/forums/t/18625422.aspx
A few things to keep in mind:
1. Your data should be safe but back it up first anyway.
2. Schedule this off hours if possible as you won't lose access to the data during the re-striping process but performance will be degraded and it will most likely take hours to complete.
1 logical harddisk degraded, RAID Poweredge
Revert back to original configuration of hdd in your RAID setup. Boot to SCIS BIOS and double check functionality of hard drives. The error is probably telling you that Disk1 is degraded because disk 0 is failing and you removed the wrong hard drive.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
