Try this online web cam test https://www.onlinemictest.com/webcam-test/
also check device mgr to be sure web cam is functional with drivers
SOURCE: Trouble downloading skype
Can't DOWNLOAD it or can't INSTALL it? Are you saving it to your computer first to install it later, or are you trying to install it while downloading? Save the files to your computer first, then run the install when the download is complete. What method of internet are you using (cable modem, DSL, dial up)?
SOURCE: Inspiron 1525 integrated webcam driver
The location you download drivers to does not matter, windows installs them to the proper location. Either the cam or the connecting cable has failed.
SOURCE: Inspiron 1525 Webcam driver error
go to techbuddies.org.. guaranteed solution to your problem... they will surely help you out in minutes..
SOURCE: my dell inspiron 1720 laptop webcam doesn't work for most program
you can have the webcam workin for only ne application at a point in time also check to see that you have activated the webcam access on the other applications and this time try with the windows firewall and other firewalls deactivated
SOURCE: my dell inspiron 1525 webcam wont work with yahoo messenger
This is happening because the Dell webcam central is accessing the webcam at the same time as yahoo messenger. Click on start and click on Run(XP), Type MSCONFIG in start search (Vista) and you'll get the system configuration utility. Open it and go to the startup tab. Uncheck anything related to Dell webcam. Click on Apply and OK and restart the computer. If yahoo messenger shows a black screen uninstall Yahoo messenger and reinstall with the more recent version.
