Sewing Machines Logo
Posted on Jan 26, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Kenmore serger I had to re thread it now it doesn't chain
Catalin Turcu
Level 3:
  • Master 4,924 Answers
  • Posted on Jan 27, 2011
Catalin Turcu
Master
Level 3:
Answers
4924
Questions
0
Helped
1232185
Points
13383
Check out the bobbin under and see if it has all that it need..and if the thread is in the right place on it ..Also check the needle to be in range ..and not shorter..(from the adjusting screw...sometimes if it is not tided well and you use some thick material ...it can move inside and being shorter it will not get to loop with the under thread ..
If you have the instructions just check it again to see how you thread it ..cause you might missed something ...
I have a Tiny Serger. The thread keeps coming out of the needle when I try to make a chain. What am I doing wrong?
first try changing the needles
make sure you have long thread tails and pull them behind the needle toward the back of the serger.
make sure there is no loose thread in the looper area
No chain being made on serger Looks like I
here is a link for a free manual,
http://www.singerco.com/uploads/download/1212_ts380.pdf
since the serger is making no chain
try new needles
rethread carefully
could also be a timing problem,, would need to be checked at a sewing machine shop
Kenmore serger thread keeps breaking
Serger thread breaks
1. Is the serger threaded correctly?
2. Is the needles inserted correctly?
3. Is one of the needles bent or damaged?
4. Is the tension adjusted too tightly?
5. Is the tension adjusted to accommodate thickness of thread being used?
6. Are you using inferior quality thread?
7. Is the thread feeding of the cone/spool freely?
8. Is the needle size correct for the type of fabric being used?
9. Are the needles being used the correct one for the serger?
Problems With the Tension serger kenmore
Open the tensions (set at zero) and have the presser foot up when threading.
Make sure the antenna if fully extended.
Turn the handwheel so the upper looper is at it's highest position.
Thread, beginning at the right thread cone unless the manual indicates differently.
After threading, set the tensions back to the recommended setting.
If this does not help, please provide more details.
1helpful
Trouble with my Huskylock 680D overlocker Tensions
You need to re-thread the serger.
Refer to the manual or open the front of the serger to see if the threading diagram is there.
With most sergers, you begin with raising the presser foot, then set the tensions to zero.
Begin the threading with the upper looper (curved looper), then the lower looper and the needles last.
Pull the thread under the presser foot and to the left side of the serger.
Set the tensions back to normal 4 - 5 usually.
Lower the presser foot and hold onto the threas tails as you stitch a chain. If the chain of the four threads is ok, you are ready to serge fabric.
1helpful
2answers
Machine is threadedand makes the serger chain for
My janome 634D driving me crazy . I have tread it properly and it wont stitch ?
5helpful
Won't form a chain stitch
You 910 serger doesn't have the option for a Chain Stitch. It is a 2, 3, or 4 thread serger. You can do a good number of different stitches but a chain stich is not one of them.
If what you mean it that it won't "chain off", meaning sew with no fabric beneath the foot as you gently pull the thread towards the rear of the machine, that could be for a number of different reasons. First, change the needles and unthread the machine and start over. If the threads are not exactly where they should be, your serger won't sew correctly. A great video on threading your machine can be seen at:http://www.husqvarnaviking.com/mediafiles/huskylock/index_en.html
2answers
2nd needle/4th thread - threading confusion
With some sergers, but not many (singer 14u64 comes to mind), the top of the stitch will be an overedge that mates with the right needle thread, and the left needle thread will appear as a separate straight stitch. When you look at the underside of the stitch, the overedge will go all the way over to the left needle (the full width of the stitch). This is normal if you have this type of machine. Another stitch some sergers do (2/4 thread sergers) is a 2 thread chain thal looks like a lone straight stitch on both sides, and a 2 thread separate overedge.
As far as the threading of the takeup, it totally depends on your model. Always post your model number when you have questions as sergers vary greatly in design.
Top Kenmore Sewing Machines Experts
ZJ Limited
ZJ Limited
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
