Toshiba Satellite L640DST2N02 Laptop Logo
Posted on Jan 08, 2011
I have l640 satellite toshiba laptop which comes with windows 7 but i have succcessfully loaded windows xp. everything runs well except sound
Anonymous
Level 1:
New Friend:
  • Contributor 16 Answers
  • Posted on Jan 08, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
16
Questions
0
Helped
1713
Points
50
Toshiba Satelite A150-S4184,Hasent been used much,It was verry fast, now have internet again and loads very slow and takes long time to load pages,I think auto downloads instales windows 7,What can I
How much memory do you have in your Toshiba Satelite laptop?
Windows XP with Service Pack 3 needs a minimum of 1GB but ideally would run better with 2GB.
Windows 7 would need the same but there is no auto-update process to go from XP to 7 as this is not allowed - you would have to do a Custom install of Windows 7 which requires a clean install (i.e. format the hard drive and start from scratch).
If you are running XP with less than 1GB memory, then you need to check what the maximum memory that the laptop can be upgraded to?
The easiest method is to use the Crucial Memory web site System Scanner utility which will detect how much memory is installed and advise how much you can upgrade to according to the options available for the specific make & model of laptop.
If the laptop hasn't been turned on or on-line for a long time then you may be using a lot of resources downloading Microsoft critical updates plus updates for other installed programs like iTunes, QuickTime, Java etc.
Try downloading and installing a copy of the free Advanced System Care 5 utility then running the Deep Care tools which include System Optimisation and clean-up utilities to improve system performance.
Where do I go to get the list of the hardwares installed in my toshiba satellite L640? Is there a website for this?
The official Toshiba site
http://us.toshiba.com/computers/laptops/satellite/L640/available-models
2helpful
3answers
Can windows 7 run on toshina satellite m45-s165
Hi, to have a good answer please download from Microsoft webpage the program that let you check if your hardware is good for Windows 7.
You can download it here
http://windows.microsoft.com/en-US/windows/downloads/upgrade-advisor
1helpful
Upgraded a Toshiba Satellite P105 S6024 from XP to Windows 7 but I have no sound
your sound drivers from windows xp doesnt support windows 7 look up sound driver and trouble shoot buy right clicking it.
I have Toshiba L640 laptop with Windows 7 and i was using laptop, suddenly dumping started and then it restarted...two days before it also happened i just put my laptop's flap down when some processes were...
Make sure your video drivers are up to date as they can cause the blue screen. Click on Start/All Programs/ Windows Update. Click on Check for updates, once it searches for updates go through the optional updates and install any optional updates for your hardware like video, motherboard, sound, drivers ect.
As a last resort you can go to toshibas website and under support download toshiba drivers and install them.
1helpful
2answers
I am connected to the internet, but IE won't load up? Also there is nothing in the box under Internet Options,Connections, then a box that should state the connection...
Hello, make sure you install all your drivers...it sounds as if you haven't got the network device driver (lan) loaded..
Regards,
Nicam49
How to install windows 7 on toshiba satellite L640?
If it meets the requirements for Windows 7, put the disc in the drive. Reboot, and choose to "boot from cd/dvd drive" (should be one of the f key's, your bootscreen will prompt you on it. After you boot from disc, follow the windows steps for installation.
1helpful
Webcam does not run
Windows 7 is a brand new OS from windows your webcam may not have a compatible driver for this version of windows as of now.
2answers
No sound coming from laptop
did you have the laptop/notebook from new if so then you should have had a set-up disc containing all of the drivers needed to activate items such as modems,sound card,graffics card etc.
this is just a simple problem and can be rectified instantly by inserting set-up disc and loading all avaliable drivers!
if no disc avaliable then log onto the toshiba website and download the up to date drivers needed for your laptop/notebook
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
