When the EEPROM programming malfunctions, DTC P1792 will set.
The EEPROM
must be re-programmed. If the re-programming is unsuccessful, DTC P1792
will remain set and the PCM will have to be replaced.
Hope this helps.
DnC Sourcing is to make an Expert of developing products. ---> www.artdnc.com (82) 70-7893-2100)http://www.sourcingbuysell.com
We have 15 years developing experiences and will implement the advanced products to our customer.
Electronics, home appliances, sporting goods, medical products, smart phone, General Phones, machine equipment, cattle. Midsize engine
* Mechanical design, tooling, product design, machine design, reverse engineering (image), product design, MOLD Analysis
* Processor: AVR series, DSP, FPGA, ARM7, ARM9, etc.
* Circuit design, PCB ARTWORK Use Program: ORCAD, PADS
70% Motor Sales ---> www.buysellmotor.net, sourcing everything ->http://www.sourcingbuysell.com
Hi
Firstly what country are you in? if in the US the OBD codes are diffeernt from the UK but I know both issues regadless.
Normally in the UK the code is for the Engine Coolant Temperature Sensor but I have known people to repair this fault and still have an engine light, normally removing the battery and then reconnectin it 1 hour later does the job " make sure you know your radio code though" also though sometimes you will find the fault is the ECM and you would have to have that programmed at a GM dealer normally thats Vauxhall in the UK.
Get back to me with your country and I will give you further info
Regards
Dan
SOURCE: Code P1792
P1792;
It's Either / OR; IF your car have those systems:
Powertrain - Manufacturer Controlled DTC - Manufacturer Controlled;
AT - engine control module (ECM)
OR;
ECM to TCM Engine Coolant Signal (4L30-E Transmission),
OR;
AT - AT EEPROM checksum error
OR;
Barometric pressure (BARO) sensor - circuit malfunction
Caused by your
ECM/Programming
OR;
Key on or engine running, then the PCM detected that the ECT sensor signal was below the lower or over the upper limit, or that the ECT signal was unreliable, conditions met for one second
Try it, & PLZ; let me know if I add any benefits to you.
I hope I add some thing valuable to you.
Regards;
MAR;
[email protected]
P1512 Throttle Position Sensor Idle Switch Sense Circuit
P1513 Throttle Position Sensor Idle Switch Sense Circuit
P1514 Park/Neutral Position Switch High Load Neutral/Drive
P1516 Gear Change Park/Neutral Malfunction
P1517 Engine Cranking Park/Neutral Malfunction
P1607 MIL Output Circuit
P1608 Automatic Transmission
P1609 Internal ECM Error
P1641 Fuel Pump Relay No. 1
P1646 Fuel Pump Relay No. 2
P1739 Automatic Transmission
P1775 Transmission Control Module MIL Circuit
P1776 Torque Reduction Request Signal
P1777 Torque Reduction Circuit
P1780 Automatic Transmission
P1781 Automatic Transmission
P1782 Automatic Transmission
P1783 Automatic Transmission
P1785 Automatic Transmission
P1790 Automatic Transmission
P1791 Automatic Transmission
P1792 Automatic Transmission
P1794 Automatic Transmission
P1796 Automatic Transmission
as you can no such code exists for a jaguar ,contact code reader manufacturer
