Last night the sound on my Sony KDF 50E3000 was working fine. This morning the TV does not play sound. We have checked the cable, DVD, and gaming system - no sound with any of it. I have checked the volume and muting. It looks like the settings are all correct. Does this happen often with these tvs?
Hi, If lamp in tv has not been replaced in last 2-3 years then it is time to replace it as tv shuts off and turns On itself is symptom of dying lamp that need to be replaced. Lamp replacement procedure is easy and written in user manual. Thanks.
Hi, Sony KDF-50E3000 is LCD Rear Projection tv that has one lamp as back light source and optical unit (light engine) generates image that projects on front screen of tv, it is similar to multimedia projector technolog. Lamp part number is F93089000 XL-2500 utilized in this model. Thanks.
i see a couple possibilites. im not going to rule out a bad lamp. the lamp does come on sometimes. i have seen faulty lamps display this sympton. since it gives no error codes (blinks) and then does not shutdown. i feel this is a deeper cuircit board problem that a tech might need to troubleshoot. how long has it been since lamp been replaced
Regarding the problem with the sound on your DVD player, I would suggest you to make sure the audio cables (red and white) are connected properly to the TV and player.
Also, try using a different set of cables since those ones might not be working and this is why you are not getting audio. On the Memorex remote you will find a mute button, make sure it is not activated.
Do this from the remote while the TV is off. In sequence (within 3secs) press "Display" - "5" - "volume +" - then "power". wait 30sec then press "8" and "enter". This will reset the TV back to factory settings. If you still have trouble then something has failed in the set.
check your connections again and ensure you have the audio going out. With many tv's you need to change a setting in the menu, double check that as well.
check the video input cables for any damage or broken part. check either ur tv or the player for any setting against NTSC, PAL or SECAM. Or try the tv with other player or try the player with other tv.
Hi, If it is Sony KDF-50E3000 TV then its symptoms of weak Lamp that requires replacement. You can purchase required XL-2500 Lamp from Sony Accessories Store. Always buy Sony Original Lamp for your TV and avoid aftermarket / cheap lamp. Thanks.
