SOURCE: motherboard drivers
you can get the drivers at the link below, but give it time the site is very slow to load. http://www.chaintechusa.com/eng/a41_product_downloads.php?type=pro&mk=162&sk=
SOURCE: user's manual
I can't find a heavy manual but here is a link may be useful to you: http://www.hardwarezone.com/articles/view.php?cid=1&id=1834
SOURCE: DRIVERS FOR CHAINTECH CT-9BJA MOTHERBOARD
U go to google.com and type the below words
"Download the drivers for CT-9BJA motherboard.
after u get a list in that u select the first option and click on translate this page
Then u get the entire motherinfo for ur model.
Pl try it
was this soultion useful?show ur appericiation by rating it
SOURCE: need sound driver info for asus motherboard k8m800
There should be a sticker on your notebook with the correct model number.
Make sure your audio is enabled within your bios.
Here is the like for Asus M70 series systems;
http://www.asus.com/Search.aspx?SearchKey=m70
Once you find your correct model, "example": M70SA-B1. Create a folder on your desktop & give it a name. Download the audio driver into that folder. Uncompress the audio file named simular to, Audio_VT_080130.zip
You may need the program winzip to preform the uncompression. If you do not have winzip you can download a 45 day trial version from the link below;
http://download.cnet.com/WinZip/3000-2250_4-10003164.html
Once uncompressed, run the setup.exe file.
If the above doesn't help you can call Asus tech @ 812-282-2787 EDT.
Asus will provide you with the correct model number & the link to download the audio driver software.
Cheers!
Mike
