1. Download the Oceanis Change Background (http://www.sevenforums.com/attachments/tutorials/42272d1272912523-desktop-background-change-windows-7-starter-oceanis_change_background_w7.zip)
2. Open the downloaded ZIP file and extract the Oceanis_Change_Background_W7.exe file to your desktop, then run it to install it.
NOTE: You will be prompted to restart the computer to finish installing this program.
3. When your computer restarts, you will see this as your desktop background. Click on the Oceanis Change Background Windows 7 shortcut to change your desktop background. (see screenshot below)
4. Browse to the images that you want to use and check (select) a image, or more than one image to have a desktop slideshow. Select the Picture position for how you want the images displayed, and any desktop slideshow settings if you selected more than one image. (see screenshots below)
NOTE: These options are just like the default ones in the other editions of Windows 7 here that are now being allowed by this program by Oceanis for the Windows 7 Starter edition.
5. When done, click on Save changes.
No you can change the wallpaper for the Win 7 starter...
For
windows 7 you need install a small application on the computer... Only
with the hekp of that you can change the wallpaper for win 7 starter...
Please
use the following link..
http://bit.ly/acZ3kf
This will be helpfull to change the
background..
Use the following link to fix this issue
Its very easy
http://findtechhelp12.blogspot.com/2010/12/changing-wallpaper-in-windows7.html
1st you will need to upgrade the OS to Windows 7 Home Premium bearing in mind that it comes with Windows 7 Starter.
That is the solution.
Remeber to rate this solution.
SOURCE: about the normal temperature of dell mini inspiron 10
you can use a external fan designed for notebooks, there a syte,
http://www.dmail.pt/prodotto.php?cod=180634-107&np=1
SOURCE: fomating dell inspiron mini 10
Does it make any difference which order i put them on the computer, i have an operating system disc and a resource cd
Thank you
SOURCE: How do you change the
The easiest way to change wallpaper/desktop background is open the picture/photo, right-click and "Set as desktop background".
You can do it from the personalize options available in display settings. Right-click on the desktop, select "personalize" and click "Desktop Background" from the available lists and browse the picture/photo you want to set as desktop background.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
SOURCE: how to apply a wallpaper
hi Dear,
Right click on wallpaper (that must be JPEG file) and select set as desktop background option.
