Nikon FE 35mm SLR Camera Logo
Posted on Oct 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi, I was taking pictures with my camera and I turned the handle to get to the next picture and the button we press to open the shutter (capture the picture) I can push it but it wont click. Please tell me what to do. I need it asap for the uni. thanks
Anonymous
Level 3:
Genius:
  • Master 1,177 Answers
  • Posted on Oct 18, 2010
Anonymous
Master
Level 3:
Genius:
Answers
1177
Questions
0
Helped
219221
Points
3782
Sounds like the shutter has not fully cocked, which often happens when you get to the end of a film and the film advance won't move on a full frame. Try the film rewind crank(gently). If it is not able to turn either way, then you have used up a film and have to rewind it and remove it from the camera. You will then be able to advance the film wind lever to finish cocking the shutter and it will fire as normal.
  • maria_tofali Oct 18, 2010
    actually it was at the beginning of the film and I did all these. the only problem is that the button wont click....
Don't know what buttons on back of camera are for.
Besides the auto-flash mode, you can select fill flash, flash off, self-timer, and nighttime-view with or without flash.
Press the MODE-SELECTOR BUTTON until the desired indicator appears on the LCD PANEL.
c3015.gif Fill flash and flash off modes remain selected after you take the picture. To cancel the selection, press the mode-selection button or close and reopen the lens cover/flash to return to the auto-flash mode.
Fill flash
c3014.gif When bright light indoors or outdoors comes from behind the subject (backlighting), dark shadows (especially on faces) may occur. Use fill flash to lighten these shadows.
  1. Open the LENS COVER/FLASH to raise the flash and to turn the camera ON.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the FILL-FLASH INDICATOR appears on the LCD PANEL.
  3. Frame your subject within the VIEWFINDER EYEPIECE.
  4. Partially depress the SHUTTER BUTTON. When the FLASH/CAMERA-READY LAMP turns off and the fill-flash indicator on the LCD panel stops blinking, fully depress the shutter button to take the picture.
Flash off
c3013.gif When you do not want to use the flash, especially indoors where flash is prohibited, such as in theaters and museums, or when you want to take twilight scenes or distant subjects that are beyond the flash range, or capture the ambiance of existing light, use the flash-off feature. Use a tripod or place the camera on another firm support, and use high-speed film because the shutter speed in these situations will most likely be slow.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the FLASH-OFF INDICATOR appears on the LCD PANEL.
  4. Press the SHUTTER BUTTON to take the picture.
Self-timer with auto flash
c3016.gif Use this feature to include yourself in pictures.
  1. Use the TRIPOD SOCKET to attach the camera to a tripod or place it on another firm support.
  2. Open the LENS COVER/FLASH to raise the flash and to turn the camera ON.
  3. Press the MODE-SELECTOR BUTTON repeatedly until the SELF-TIMER INDICATOR appears on the LCD PANEL.
  4. Frame your subject within the VIEWFINDER EYEPIECE.
  5. Press the SHUTTER BUTTON. The SELF-TIMER LAMP will glow and then blink during the last three seconds of countdown.
    • To cancel the self-timer selection before the shutter releases, close the flash.
    • The self-timer automatically turns off after the shutter releases.
Night-view with flash
c3012.gif In this mode, the camera balances the flash and existing light exposure so you can take beautiful pictures of people at sunset or at night. Use a tripod or place the camera on another firm support, and use high-speed film because the shutter speed at night will most likely be slow.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the NIGHTTIME-VIEW INDICATOR with flash appears on the LCD PANEL.
  3. Frame your picture in the VIEWFINDER EYEPIECE.
  4. Press and hold the SHUTTER BUTTON for 12 seconds without lifting your finger. Note: If you remove your finger from the shutter button before 12 seconds, the shutter will time out immediately.
  5. After 12 seconds, release the shutter button to take the picture.
Night-view without flas
c3011.gif In this mode, you can capture the natural existing light of city-night scenes or fireworks at night. Use a tripod or place the camera on another firm support, and use high-speed film because the shutter speed at night will most likely be slow.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the NIGHTTIME-VIEW INDICATOR without flash appears on the LCD PANEL.
The display will not show anything when the camera is turned on. All the options are on the screen but nothing else. It is black.
First off you didn't say if the pictures it is taking are OK, or if they are also black. If the pictures are turning out fine, then it's likely that you just accidentally pressed the DISP or DISPLAY button on the back of your camera, accidentally turning the screen off to save batteries. Press the button one more time to turn it back on.
But if the pictures take are also black, then a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Not capturing pictures
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help:
2helpful
I have no display on my lcd screen when taking pictures...but do have display when reviewing pictures. HELP!!
First confirm that you didn't accidentally press the DISP or DISPLAY button on the back of your camera, manually turning off the display. (Press it once with the camera turned on just to make sure). If that didn't fix it...
Power shot a620. screen is not showing pictures, all icons are there but screen is black? Help please!!
Sounds like you might have accidentally pressed the DISPLAY button on the back of your camera. It turns the screen on and off to save batteries. Turn on your camera, and press this button once again to turn the screen back on.
But if your camera is also taking black pictures,
1helpful
My canon powershot SD1100 IS camera lcd screen isn't working. Its black when i try to view the picture and take the picture
You may have just accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the screen on and off to save batteries. You would then use the optical viewfinder in its place. Press the DISP button once with the camera turned on to see if that corrects the problem. If this doesn't correct it...
How do I set a shutter delay on a cx4230 camera?
It is easiest to link you to your camera manual.
Click on:
Kodak CX4230 Manual
Go to page 20 in the manual for instructions.
While you have it open, save a copy to your computer for future reference.
Here it is if you don't want to do that:
In Capture mode, press the Menu button.
Highlight Self Timer , then press the Select button.
Highlight On, then press the Select button.
Press the Menu button to turn off the menu screen.
Place the camera on a flat surface or use a tripod.
Press the shutter button completely down to take the picture.
The red Self Timer light turns on for 8 seconds, then blinks for 2 seconds. The picture is taken.
Why does the camera take so long to take a picture?
You may be pressing the shutter all the way down at once. This forces the camera to focus, make exposure adjustments, and capture the image all at once. By pressing the shutter button partially to focus, then the rest of the way to capture the image, your camera can process pictures more quickly. You can turn on quick shot mode to take pictures quickly.
2helpful
Slow response time
Before a digital camera is ready to take a picture, the electronics inside the camera must get ready to capture the picture and save it to the memory card or the internal camera memory. Press the shutter button half-way (to its first detent) to set the exposure and focus. When the ready light is green, continue pressing the shutter button completely down to take the picture. The picture is taken almost immediately.
Top Nikon Photography Experts
Tony Parsons
Tony Parsons
Pallikonda Nisha
Level 1 Expert
Are you a Nikon Photography Expert? Answer questions, earn points and help others
