20 Most Recent Kodak Advantix C400AF APS Point and Shoot Camera Questions & Answers
Besides the auto-flash mode, you can select fill flash, flash off, self-timer, and nighttime-view with or without flash.
Press the MODE-SELECTOR BUTTON until the desired indicator appears on the LCD PANEL.
c3015.gif Fill flash and flash off modes remain selected after you take the picture. To cancel the selection, press the mode-selection button or close and reopen the lens cover/flash to return to the auto-flash mode.
Fill flash
c3014.gif When bright light indoors or outdoors comes from behind the subject (backlighting), dark shadows (especially on faces) may occur. Use fill flash to lighten these shadows.
  1. Open the LENS COVER/FLASH to raise the flash and to turn the camera ON.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the FILL-FLASH INDICATOR appears on the LCD PANEL.
  3. Frame your subject within the VIEWFINDER EYEPIECE.
  4. Partially depress the SHUTTER BUTTON. When the FLASH/CAMERA-READY LAMP turns off and the fill-flash indicator on the LCD panel stops blinking, fully depress the shutter button to take the picture.
Flash off
c3013.gif When you do not want to use the flash, especially indoors where flash is prohibited, such as in theaters and museums, or when you want to take twilight scenes or distant subjects that are beyond the flash range, or capture the ambiance of existing light, use the flash-off feature. Use a tripod or place the camera on another firm support, and use high-speed film because the shutter speed in these situations will most likely be slow.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the FLASH-OFF INDICATOR appears on the LCD PANEL.
  4. Press the SHUTTER BUTTON to take the picture.
Self-timer with auto flash
c3016.gif Use this feature to include yourself in pictures.
  1. Use the TRIPOD SOCKET to attach the camera to a tripod or place it on another firm support.
  2. Open the LENS COVER/FLASH to raise the flash and to turn the camera ON.
  3. Press the MODE-SELECTOR BUTTON repeatedly until the SELF-TIMER INDICATOR appears on the LCD PANEL.
  4. Frame your subject within the VIEWFINDER EYEPIECE.
  5. Press the SHUTTER BUTTON. The SELF-TIMER LAMP will glow and then blink during the last three seconds of countdown.
    • To cancel the self-timer selection before the shutter releases, close the flash.
    • The self-timer automatically turns off after the shutter releases.
Night-view with flash
c3012.gif In this mode, the camera balances the flash and existing light exposure so you can take beautiful pictures of people at sunset or at night. Use a tripod or place the camera on another firm support, and use high-speed film because the shutter speed at night will most likely be slow.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the NIGHTTIME-VIEW INDICATOR with flash appears on the LCD PANEL.
  3. Frame your picture in the VIEWFINDER EYEPIECE.
  4. Press and hold the SHUTTER BUTTON for 12 seconds without lifting your finger. Note: If you remove your finger from the shutter button before 12 seconds, the shutter will time out immediately.
  5. After 12 seconds, release the shutter button to take the picture.
Night-view without flas
c3011.gif In this mode, you can capture the natural existing light of city-night scenes or fireworks at night. Use a tripod or place the camera on another firm support, and use high-speed film because the shutter speed at night will most likely be slow.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the NIGHTTIME-VIEW INDICATOR without flash appears on the LCD PANEL.
Kodak Advantix... | Answered on Jul 13, 2010
To the best of my knowledge all 35mm cameras load identically, apart from a few automatic models that claimed to be self loading.
A new film cassette has a tongue of film protruding. Once the cassette has been loaded into the recess on the left and the rewind crank pushed down and engaged with the film spool, a couple of inches of film is pulled from the cassette and the tongue poked through the slot in the takeup spool - it might be necessary to use the film advance until the slot is visible.
With about a half-inch of film pushed through the slot, slowly advance the film until the slackness is gone while fully engaging the sprocket holes at the edges of the film on the teeth of the sprockets. Advance the film a little more to check it is properly engaged and once you are satisfied close the camera back firmly making certain the catch is engaged and it won't spring open again.
Once closed, advance the film until it stops which signals the shutter is set and is ready to take a photograph, however the first and perhaps the second frame has been contaminated with light and so press the shutter release, advance and press again and the third advance is where the photographs begin. If there is a frame counter it is best to be guided by this.
Cameras that have a manual advance usually have a manual return crank that will be seen to rotate as the film is advanced. When all the frames have been used the film will be felt to come to the end. At this point the clutch button must be pressed to disengage the wind-on mechanism and the film wound back into the cassette using the crank on the left.
Kodak... | Answered on Sep 30, 2020
Again, most kind of you to pass on this information. Was there any particular reason behind your doing so ?
Kodak... | Answered on Aug 24, 2017
If you are disabled, and use a walking frame, you should be able to get assistance from the Social Services department of your local council
Kodak... | Answered on Aug 17, 2017
Sorry these types of items are not serviced. My suggestion is to make one.
Kodak... | Answered on Jan 11, 2017
Kodak Advantix C400AF APS Point and Shoot Camera Logo
1 questions posted
Top Kodak Photography Experts
Davit Mamyan
Davit Mamyan
Muntejaya Ginting
Muntejaya Ginting
Harrie
Are you a Kodak Photography Expert? Answer questions, earn points and help others
View Most Popular
Kodak Photography
  • Kodak Photography
Most Popular Question
dont know buttons back camera
  • Photography
