Microsoft Office PowerPoint Home and Student 2007 for PC Logo
Posted on Jul 13, 2017
Uniblue's registry booster 2010 can't scan because of microsoft 2007 error mesage coming up. it says in a dialogue box: Microsoft Visual C Runtime Library runtime error program:C:\... this application has requested the Runtime to terminate it in an unusual way. please contact the applications support team for mor info. then this code came up: C:\DOCUME~1\Hp_own~1.YOU\LOCALS~1\temp\3ba7_appcompat.txt what does this mean?
3 Related Answers
Anonymous
  • 25 Answers
  • Posted on Dec 28, 2007
SOURCE: compleate updates not done
First Scan u'r PC with a good antivirus(Should be updated to latest).
Check Internet connections.
If still not... Then make repair with OS cd.
Anonymous
  • Posted on May 03, 2009
SOURCE: My XP Pro was corrupted after Microsoft made me activate again.
restriction in effect on this computer
Anonymous
  • 830 Answers
  • Posted on Sep 16, 2009
SOURCE: excel not working upon start up
Make sure that you have all the updates for Microsoft office by visiting Mocrosofts website and download the hotfixes.
If that doesn't work
Try uninstalling office and reinstalling to fix the problem.
2answers
Incorrect side by side configuration when i try to open my yahoo messenger
remove it from control panel add or remove programs and install it again
tip
Microsoft Visual C++ Runtime Library error when starting Roxio creator
Hi.
I have had several questions from users getting Microsoft Visual C++ Runtime Library errors when starting Roxio Creator 2010 and previous versions.
After the error prompt, the software will close down.
The problem is caused by a system error , and this sometimes is causedby Microsoft self installing update, that confuse settings of installedsoftware.
Microsoft Visual C++ Runtime Libraries are part of the operativesystem, and this kind of Run time errors are commonly caused whenapplications try to access resources that are allocated for otherprocesses.
A new Roxio installation did not fix the problem, because the newinstallation will still keep the registry settings from oldinstallation.
If the problem started recently you can try the following:
Uninstall Roxio.
Do a System Restore to a date before the problem started.
Reinstall Roxio.
See: How to install System restore.
If that does not fix the problem you can also try the following;
Uninstall Roxio
Create a new user with administrator privileges
Log in using the New User account
Install Roxio again.
If the problem was bound to local user settings, this will fix the problem.
If the problem is still there, then the most efficient way to proceedis by doing a new Windows installation, using a Windows setup disk or arecovery disk for your computer.
Do a full backup of your data before reinstalling Windows.
See:Install, reinstall, or uninstall Windows
The solution does not apply only to Roxio, but can fix the same problem on different software.
Regards.
on Feb 26, 2010 • Computers & Internet
I have directx 10 but still can not fix the Runtime Error 429. What should i do?
Error 429 issue is caused by corrupted Windows registry.
The first tips to fix runtime error 429 is to run security scan on your computer.
http://www.filehippo.com/download_spybot_search_destroy/
Repair your system's registry with http://download.cnet.com/RegScrubXP/3000-2094_4-10820427.html
Also you can try to go to the Microsoft Windows Script update page to fix runtime error 429. http://www.microsoft.com/downloads/en/details.aspx?FamilyID=47809025-D896-482E-A0D6-524E7E844D81
If possible download XP SP3 http://windows.microsoft.com/en-US/windows/help/learn-how-to-install-windows-xp-service-pack-3-sp3
Hope my solution will help you...
Have a Nice Day
1helpful
I am looking for key for uniblue registry booster?
go to www.filefortune.com sign up and you can download the key.
How to fill serial number of registry booster 2010
Open Registry booster 2010, then Click Register on Lower Left Corner, then fill your registry booster 2010 Serial number.
Don't have Registry booster 2010 serial number?
Click Here:
http://www.google.com/search?q=What+is+Registry+booster+2010+serial+number&rls=com.microsoft:en-gb:IE-SearchBox&ie=UTF-8&oe=UTF-8&sourceid=ie7&rlz=1I7GGLL_id
1helpful
I was running Apex free 3gp video converter on a vista run computer and it pulled up the error sign Microsoft Visual C++ Runtime Library Runtime Error!
Microsoft Visual C++ Runtime Library Runtime, you need to download that and install it. This should clear the error. support.microsoft.com/kb/25940
1helpful
Microsoft Visual C++Runtime Library
hello there
please follow this link for a explanation and a fix for this ok
  1. "Microsoft Visual C++ Runtime Library Runtime Error" error message ... Describes the error messages that you receive after you install Office XP or an ... "Microsoft Visual C++ Runtime Library Runtime Error" error message after you ...support.microsoft.com/kb/307817
Error in registry....
Maybe, you have registry problem.
  • Just restart the system
  • Press F8 while starting the windows
  • Select "Safe Mode" options
  • After restarting, a window will come up on screen
  • select No
  • Just select the past date from the date calender. You must select a past date from which you were not facing problem.
  • A restore process will start automatically.
  • press okey and finish
  • restart the computer.
I cannot run Visual Studio 6 on Acer Aspire 5920
No I don't think that is the problem here, what kind of CPU do you have? Is it a AMD 64-bit processor? The application is triggering an invalid register in the system command processor. More than likely that version of Visual Studio had limited support for the AMD CPU... multi-core... x64... You can try updating Visual Studio with the last service pack offered or upgrade to something like Visual Studio .NET 2005 (VS 8.0). Microsoft offers the Express Versions for free online... I doubt you'll have a problem with a modern high-level compiler; you can also run a Registry Repair Tool to see if there are any invalid registry entries. I use Uniblue Registry Booster because they're a Microsoft Certified Partner.
Microsoft Visual C++ Runtime Error
Download
http://www.microsoft.com/downloads/details.aspx?FamilyID=32BC1BEE-A3F9-4C13-9C99-220B62A191EE&displaylang=en
Microsoft Visual C++ 2005 Redistributable Package (x86)
Brief Description
The Microsoft Visual C++ 2005 Redistributable Package (x86) installs runtime components of Visual C++ Libraries required to run applications developed with Visual C++ on a computer that does not have Visual C++ 2005 installed.
hope this solves your problem it should
have fun
The Doctor
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
