The newer SATA drives are faster than the previous-generation IDE drives.
Does the power-supply on the Dell have power-connectors that are compatible with the power-socket on your IDE drive?
Does the motherboard have a slot for the 80-pin "ribbon-cable" to connect between the motherboard and the 40-pins on the back of your IDE drive?
The answer to both questions is no. But I have spare parts, including a power supply with both styles. Im trying to get my old IDE drive into a newer computer. I dont see the 80-pin motherboard connector but am not sure.
One "general" solution is an external adapter with one end that plugs-in to a USB port,
and the other end connects to an IDE disk-drive.
See: http://cgi1.ebay.ca/ws/eBayISAPI.dll?Vie...
I use one to "temporarily" connect an old IDE drive to a new computer, to copy files.
The IDE disk-drive is "bare", i.e., not inside an external case.
But, if you want to connect an IDE disk-drive for one or two hours, this adapter is a handy and "reusable" tool.
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as a faulty electrical extension or fan lead can cause you problems
computers need all of the data and electrical current to travel through every working device and to have an end to be able work properly
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
also check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in
check you CPU make sure its securely seated and has thermal grease
hope it helps
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to boot
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
