20 Most Recent Dell DimensionTM E520 PC Desktop Questions & Answers
The LED lights on the Front Panel are Diagnostic Lights.
LED's 3, and 4 being illuminated, indicate a problem with the ram memory modules (Sticks), according to Dell.
This is Dell Support, and the Service Manual main menu, for the Dimension E520,
http://support.dell.com/support/edocs/systems/dime520/en/SM_EN/index.htm
On this main menu page left-click on - Advanced Troubleshooting.
Now click on - Diagnostic Lights
Look at the chart.
My diagnoses is different. I think it is a Power Supply issue.
Do you have more than one ram memory module ('Stick') installed in your computer?
[NOTE*
Basic procedure, implementing safety guidelines both for you, and your computer.
Computer off, And unplugged from power.
Open the computer case, and touch the metal frame.
Your body carries Static electricity. Touching the metal frame of the open computer case, will relieve your body of Static. (Computer unplugged from power first)
Static electricity will fry out, (Short Circuit), the hardware components inside a computer ]
In the main menu you can click on - Removing and Installing Parts, for guidance in opening your computer case, and removing/installing ram memory modules.
(Removing the Computer Cover, and Memory, respectively)
If you have one memory module, remove it, and clean the gold plated contact pins on the bottom, with a pencil eraser.
Use care, and refrain from touching the contact pins with your fingers.
You can hold the ram module anywhere on the body of it, as the body is coated with a see-through plastic.
Apply the pencil eraser to the top of each contact pin, and stroke down with the eraser.
A side to side motion is not a good idea, as well as starting from the bottom of the contact pin, and going up.
[This is DDR Sdram, and not DDR2 Sdram that is used in your computer.
I linked it to show you a close up view of the gold plated contact pins, and the Black DRAM chips on the side of the ram module,
http://en.wikipedia.org/wiki/File:Generic_DDR_Memory_%28Xytram%29.jpg
The top of the contact pin is is close to the DRAM chips.
{DDR Sdram has 184 contact pins. 92 on each side.
DDR2 Sdram has 240 contact pins. 120 on each side]
After you clean the contact pins with the pencil eraser, use air from you, or a can of compressed air for computers, to remove the eraser 'dust'.
If you have more than one ram memory module, do the above procedure for all of them.
With having just one ram memory module, reinstall it back into ram memory Slot 1.
(DIMM 1 may be stamped on the motherboard next to ram Slot 1.
Slot 1 is the ram slot that is closest to the Processor, that is sitting at an angle on your motherboard)
If you just have one ram memory module, place it in Slot 1.
If you have more than one ram memory module, pick one, and install it in ram Slot 1.
Do not close the computer case at this time. Plug the computer back into power. WAIT 1 minute, turn the computer on.
Still No?
If you have more than one ram memory module, use it in Slot 1. Test again.
If the second ram module you try works, then the first ram module is bad.
If you have just one ram memory module, and this test resulted in the computer not working, the diagnoses is that you have a bad ram memory module.
Same thing if both ram modules do not work, if you have more than one ram memory module.
I think it is the Power Supply is bad, due to the fact that the computer, 'Fell to it's knees', when you tried to turn it on the second time.
Bad voltage power rail. Not enough power from the power supply to turn the Processor on, and keep it running.
Computer power supply's power is rated in Watts. (Wattage)
Voltage times Amp's = Watts
1) ALL the lights use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts of power.
3) A typical Processor uses 55 to 125 Watts of power.
When you press the Power On button, 5 Volts of standby power is redirected to the Power Supply.
This turns the Power Supply on.
The first chip to receive power is the BIOS chip.
The BIOS program burned into that chip, looks to see what devices are connected, does a Ram Memory count, turns the Processor on, and hands the computer over to the Operating System.
(Windows XP is an example of an O/S)
I believe you do not have enough power to turn the Processor on.
There is a way to test the power supply with a power supply tester, (About $15)
Or a known, good, and compatible power supply, can be used for a test.
(One more thing to Note*
For a time period Dell built their computers as a Proprietary computer design.
This means they wanted THEIR computer parts, installed in THEIR computers.
The main proprietary item at that time was the Power Supply.
This is in reference to the 24-pin ATX main power cable connector, and the wire placement in that connector.
Close up examples of a 24-pin main power cable connector, (In your Dell computer this connector has P1 stamped on the side),
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
Look, at your 24-pin ATX main power cable connector on your Dell power supply, and observe the color code of the wires.
Use the lock tab on the side of the connector, to orient where the wires are placed.
Now look at the 24-pin ATX main power cable connector for the power supply you are wishing to use.
The color code of the wires MUST be in the same.
Dell DimensionTM... | Answered on Feb 07, 2018
So many computer face this blue screen fetal errors on windows.
This error comes usually when there is problem in software or driver compatibility issue with hardware or operating system.
Also this error comes when there is bed indexing unit in hard drive.
You can solve this errors with following 2 methods.
(1)When you power up the computer press F8 key then enter in safe mode.
Then if you are able to enter in safe mode then uninstall driver or software which you installed recently and face this error.
(2)If you are not able to enter in safe mode Then you need to fix error on hard drive.For that you need windows disk or recovery disk.
Boot your computer with that disk
For that when you power up the computer press F1 or F2 "del" key to enter in bios.
Then go to boot menu and set first boot device as your cd or dvd rom.
Then save settings and exit bios.
Insert windows disk in cd /dvd rom.
Then it boot with that disk.Then you get this message "Press any key to boot from cd.."
Then press any key.
Then follow the procedure then enter in recovery console mode then type in prompt "chkdsk /r"
Then type "y"
Then it fix error on hard drive.
Then check if again you are not able to enter in windows then boot again and this time choose "R" option for repair previous windows " then it repairs old windows then it loads again old windows.
Thanks for using FixYa.
Dell DimensionTM... | Answered on Jun 20, 2014
Here is an explanation of your problem - http://support.microsoft.com/default...;en-us;Q314474
and ways of fixing it. Regards.
Download the file here http://www.dlldump.com/download-dll-.../download.html and replace the corrupted file .. it should be in C:\Windows\system32
When you boot up, go into Safe Mode (tap the f8 key as its starting to boot up and select Safe mode from the resulting menu). Now go to the 'problem' dll, right click on it and select rename. Rename it to ntdll.dll.old then paste the new .dll into the system32 file
Hope this helps
Dell DimensionTM... | Answered on Apr 16, 2014
Not if you have a 32 bit bus motherboard.
Dell DimensionTM... | Answered on Nov 02, 2013
Reconnect the keyboard or test with another. It will not boot without it.
Dell DimensionTM... | Answered on Feb 04, 2013
This is an error code that means Problem Booting Response hold down your Ctrl+Alt+Delete and see if it does not reset the boot series. it means a corrupt boot code you can try and use F2 to try to get into Bios and then f12 to get to the hard drive reboot option.
Dell DimensionTM... | Answered on Jun 07, 2012
I would double check the connections to the main board. Some power supplies have two power connectors to the mother board, a 20 pin connector and a 4 pin connector. Sometimes the four pin connector is in a different location from the 20 pin on the board. Make sure both connectors a plugged in.
Make sure the connector for the power switch is plugged into the board. Dell's usually have all the wires for the front pane in one connector.
You should also unplug everything from the board except the power supply and front panel. There could be a hard device causing the board to hang up.
I have had power supplies die and short the main board. I hope that isn't the case here.
Dell DimensionTM... | Answered on Jul 02, 2011
You will need to replace it.
Dell DimensionTM... | Answered on Apr 24, 2011
No. There is a mic jack on the front panel and the back of the computer where you can plug one in.
Dell DimensionTM... | Answered on Feb 20, 2011
My guide entitled My Computer is not turning on!!! Is it dead!!! No POST!!! will help you to sort out your problem.
Thanks
damnor01
Dell DimensionTM... | Answered on Nov 14, 2010
1. This is possibly due to a malfunctioning power supply if the monitor works on another PC then the summation is the power supply is not giving the +5/-5 -12/+12 volts to the mother board to power the video card and other peripherals.
2. Your power supply will need to be replaced.
I hoped this helps. Have a Great Day!
Dell DimensionTM... | Answered on Sep 25, 2010
1) Download and install a programme called Ccleaner from Filehippo.com.
a) run the cleaner - gets a load of web rubbish off your pc you
didn't know you had.
b) From the menu on the left, select startup, delete all programmes out
of your startup menu except for antivirus and firewall programmes.
2) Disconnect all power, get a natural bristle paint brush and hoover
and, carefully, clean out all the dust and fluff from your pc. (over
heated cpu's step down in speed)
3) Add more ram if still necessary. go to the "Crucial" web site, enter
the details of you pc. Tells you what kind of ram and how much your
PC can run. Bear in mind XP can only use a maximum of 3Gb. You
don't have to buy from here, if you decide just use the info.
Dell DimensionTM... | Answered on Jul 20, 2010
You may need a new power supply. Are you certain that you are getting no power? If you open up the side of your PC, most Dell motherboards have a green light. If you are seeing a green light, you are getting some power.
Are you sure that it is plugged in? Some machines have an on/off switch by where the plug goes into the power supply. If it off, turn it to on and press the button on the front of the machine.
Dell DimensionTM... | Answered on May 27, 2010
try to play another speakers in the same sound card if the problem persist then change the sound card
Dell DimensionTM... | Answered on May 02, 2010
try to clean it from the dust. lot of people had the same problem and fixed it like that.
Dell DimensionTM... | Answered on Apr 07, 2010
Yes, Most of the laptops will come along with built in microphone and speaker.
Revert back for more assistance and give your valuable feedback/rating for the solution provided.
Thank you for using Fixya.
Dell DimensionTM... | Answered on Mar 03, 2010
Dell DimensionTM E520 PC Desktop Logo
32 questions posted
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
View Most Popular
  • Dell Computers & Internet
Most Popular Question
replace power supply
  • Computers & Internet
