If you can enter the bios, you can load failsafe settings.
Your manual is here, it is very slow to download, so i gave up half way through :)
http://www.abit.com.tw/page/en/download/download_manual_detail.php?pFILE_TYPE=Manual&pMAIN_TYPE=Motherboard&pTITLE_ON_SCREEN=AL8-V&pSOCKET_TYPE=LGA775
Just look for the silver battery. Either remove battery and replace, or look for jumper (closest to battery with one pin showing, and two covered by the jumper) Remove the jumper and place over middle and previously uncovered pin, then move back to origional position.
Hope this helps
Wayne
Tech Rehab
http://techrehab.t35.com
SOURCE: 1333 FSB processor only runs with fsb set to 1066 in bios
RIArchangel, you're board is not able to run 1333fsb; it can only run at 1066fsb. Though setting the bios to auto should not cause the system to lock up, unless you are over-clocking other settings in the system bios.
Changing you're memory to the faster dual channel 667 will increase the systems over all performance but it will not change the fact that the board can only run at 1066fsb.
If you have the time, take a read over this link. 1333fsb over 1066fsb. http://www.tomshardware.com/forum/230788-30-1333-1066
Feeling spunky? You can test you're CPU with this free software. Scroll down a bit until you see, CPU Stability Test
http://www.pcworld.com/downloads/file/fid,7146-order,1-page,1-c,alldownloads/description.html
If I can help you further, feel free to post.
Suggestions & comments welcomed.
Mike
