Hi, tech specs say 1200 watts peak. what you want is RMS value and quick guide I use to comvert watts peak to Rms is divide by 3 (approx=400Wrms) Ok to drive a little harder - use 500Watt RMS amps per speaker. decision to use 1 or 2 amps depends on amp capability -use 2 x 500wrms 2 channel amps(1 per speaker bridged mode) or 1 x 1000wrms 4 channel amp (bridge 2 channels for each speaker). Whether you need to do anything about your charging system will depend largely on the capability of your alternator and the various vehicle loads that need to be supplied on a day to day basis ( use winter for worst case scenarios) as this system could be reasonably expected to consume 60 amps on large bass notes (dead giveaway is to add the fuse ratings on nominated amps). there is vast amounts of knowledge for this subject and what has been touched on here is just that
