1989 Harley FLHS no power to bike/new charged battery/is there fuses/bike ran fine tried to get blinker to work replaced lite bulb/new battery...now there is nothing not even lites
The pre-2000 models came with circuit breakers instead of fuses. They look like little metal cans that are about 1/2" wide by about 1 1/2" long. When a short circuit causes the current draw to exceed the rating of the circuit breaker, it will break with a slightly audible "ping". After a few minutes, it will reset itself. If the short circuit is still present, it will simply start the cycle all over again.
Now, there is a main circuit breaker. Usually it's under the seat and it's rated at 30 amps. It could have been replaced with a fuse by a previous owner if the bike was purchased used.
Now, at the battery or the starter, you should have an additional wire that supplies power to the entire bike. The large battery cable connects to the postive side of the battery and then goes down to the starter. Your bike should have the Nippondenso type starter on it as the '88 year model was the last to have the seperate starter solenoid and Hitachi starter. At one or the other places, the starter or the battery, there should be a large single wire connected along with the battery cable. This wire is the what I call the "accessories" power wire. It must be connected or there will be no power to the rest of the bike. If you failed to reconnect it at the battery, this could be your problem.
If you will contact me directly and tell me you need a schematic for your '89 FLHS, I can send it to you e-mail. [email protected]
Good Luck
Steve
