2008 Yamaha Yamaha G5 Logo
Posted on Jun 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Yamaha banshee will not start
My 2005 yamaha banshee will not start. i have spark at the plugs. it done this once before and i clean the plugs and adjusted the gap and worked fine. now i replaced the plugs and no start
Steve P
Level 3:
  • Yamaha Master 3,912 Answers
  • Posted on Jun 06, 2017
Steve P
Yamaha Master
Level 3:
Answers
3912
Questions
5
Helped
1307969
Points
15904
Did you accidentally cross the spark plug wires?
Other wise its going to be hard to diagnose,
Do you have plenty of compression,
Are you getting gas to the spark plugs?
Is the air filter clean/new?
You will need a factory service manual to diagnose further if all the above is ok
I start my Yamaha Banshee 350 ATV, it starts fine and idles fine but when I start riding it and gets a bit over half throttle it starts backfiring really bad. Any suggestions on what to look for? TIA
Question edited for FULL 'make model (what it is)', from 'banshee'.
Question moved from Motorcycles to correct Category.
Check spark plugs.
Clean Carb.
Check timing.
More here, it is a known issue.
https://www.google.com/search?q=Yamaha+banshee+atv+backfires
1helpful
Yamaha banshee
14 - 41 = 2.93 ratio
15 - 46 = 3.06 ratio..
6-7 links.. you need to move the axle all the way forward when installing a new chain... (it will stretch!) moving the axle all the way forward gives you plenty of adjustment later!!
2answers
Why is my Yamaha Banshee is hard to start
It looks like your compression is too low (worn rings from dusted motor) Push starting spins the motor faster than kick starting and when hot the rings expand just enough to seal off. Before kicking a cold motor try putting in a squirt or two of engine oil in the plug hole to see if there is a difference.
Yamaha banshee. Just rebuilt top end and has been bored 80 over. Starts but is bogging down in low rpms. It seems to run ok in high rpms. I cleaned the carbs and replaced the reeds.
Check the plug color to see if it is normal. I would put new spark plug caps and new spark plugs on the machine and see if that helps . From what you describe , if the spark plug caps do not work , you will probably have to either , adjust your air screw setting or change your pilot jets up one size to compensate for the other changes.
1helpful
Why does my four wheeler keep back fireing and not starting?//
Could be air block in the petrol tube and clean the carborator and remove the dust and dirt to run the unit. Cleran the petrol tank atleast once in a year to avoid dust formation at the bottom of the fuel tank. Adjust the gap in the spark plug to standard specification to avoid back fireing.
2answers
Low power,backfire,bogs out,spark plug wet
Carburetor on the side that's wet, need repair.
Top Yamaha Experts
vince
Steve Sweetleaf
Steve Sweetleaf
littlewheel
Are you a Yamaha Expert? Answer questions, earn points and help others
