eBay1995 1996 1999 Nissan Maxima Pathfinder Infiniti J30 Radio BOSE CD tape Player ...Will fit and work in these with BOSE audio package only:1995 - 1999 NISSAN .... 2006Nissan Maxima OEM Bose Cassette & 6 Disc CD Player Radio CR13B ...DESCRIPTION Unit is missing some bottons, 3 of them, this item has NOT ...
eBayWill fit and work in these with BOSE audio package only:1995 - 1999 ... 1996 - 2000 NISSAN Pathfinder. 2004 2005 2006 NISSAN MAXIMA FACTORY BOSE STEREO 6 DISC ... Factory NISSAN INFINITI BOSE Radio, Tape, and CD Player. ... 6 Disc AM FM Stereo Cassette Radio Bose OEM LKQ (Fits: Nissan Maxima).
? 8:52
https://www.youtube.com/watch?v=RT-SZEfeA4Q
Sep 16, 2012 - Uploaded by Factory Car Stereo Repair
Factory Car Stereo Repair .... I have nissan maximal 05..the CD part turns on but the cd won't eject...should ... I have a 2005maxima non-bose radio system. ... my speakers is super in my 05 maxima but my cd player keeps on ...
The original radio is a BOSE system and it has a buit in amp. So if you replaced the deck you need to replace the speakers all so. Don't cut the wires to hook-up the deck buy an addapter KIT. It's not just the stereo that runs though that harness the factory alarm does all so and that will cause you problems. Anyway back to the stereo you need to add an amplifier and problem sovled.
O assume you are wanting to add a sub as bose systems are already amplified. The short answer is ues, however most bose systems require special interface harnesses and may require complex wiring. This is best left to a qualified mobile electronics shop.
each speaker in your car runs the wiring thru an amp. So each spkear has its own amp for the bose system. You can not hook up a none bose radio If you do you will need to run new wires and replace all the speakers. Sorry.
you need to pull the radio out and verify that you have 12 volts all the time at the Pink/Blue wire in the radio connector plug, this is the keep alive memory, without this constant 12 volts the radio will reset every time the key is turned off. I assume you have checked the fuses. If the wire is ok and has 12 volts present then the radio is defective and will need to be sent out for repair..
