Don't know about your particualr saw, but general instructions are : take the bar cover off, take the bar and chain off, put your piston stop in, remove the clutch nut by unscrewing it clockwise, remove the shoes and springs from inside the drum, and pouit them in the new one, replace it all. If you don't have a piston stop you can pull the starter cord all the way out and stuff some of it into the spark plug hole to stop the piston moving when you turn the clutch nut.
Harbor Freight adjustable pin wrench #36554
You provide no model, this may not be your saw.
http://www.echo-usa.com/pdf/documentation/CS300_100605.pdf
It has an external clutch, this is a good guide for removal.
R² Drive Link Outboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=cdqkIuVNUQc
If my example is not your saw you can find yours here:
EchoUSA
http://www.echo-usa.com/documentation.asp
If your saw is not listed type "CS" in the “Model:” window, click "Search" and select your saw from the list provided.
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
