Are you moving your arm at all after you press the start button. I just have a wrist cuff, but if I move anything after I've pushed the start button I get an error code.
On my Homedics BPA-110 the "E3" means there was an "error obtaining measurement data: measure again". When you measure, make sure the cuff hose is centered on your arm. I have noticed the placement of the hose cuff is quite critical. If the hose on the cuff is not centered, you will probably get some type of "Exx" error code. This has happened several times with my monitor. Hopes this helps.
Robert, I'm not sure that the cuffs would be interchangeable. But, I suspect the problem you're having with the cuff is operator error. Speaking from experience, it's somewhat difficult at best, to apply and arm cuff to yourself. It does take some practice, but if you can get the cuff snugly in place, it should inflate properly. If you want to pursue with interchanging the cuff, contact HoMedics at 800-469-3342, to see if it's possible. Perhaps, you should get a BP Monitor that has a wrist cuff. They're a lot easier to apply and use.
Homedics makes several units that are virtually identical to the Walgreen counterparts. Why not try the Homedics web site? It has a support section. Be sure to list your model number as there are several wrist cuff models. If the web site doesn't help, either call Homedics or try a web search by listing your model number followed by 'manual'. I would have tried to find the manual for you but I don't know the model number. Good luck.
