Toshiba Portege 3505 Tablet PC Logo
Posted on Apr 14, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Restore windows xp to factory settings - Toshiba Portege 3505 Tablet PC
Anonymous
Level 3:
Genius:
  • Master 1,341 Answers
  • Posted on Apr 14, 2010
Anonymous
Master
Level 3:
Genius:
Answers
1341
Questions
Helped
324560
Points
3828
If you have the windows cd then you can place the cd in the cd drive and restart the pc.Make sure your BIOS is set to boot from cd first though.Once you restart your pc, follow the on screen display and opt for repair windows. Windows can go be restored to a previous state but depending on how long the system has been running will determine the extent to which you can restore the os. hope this gives you an idea.Good luck.
Anonymous
Level 2:
New Friend:
  • Expert 108 Answers
Anonymous
Expert
Level 2:
New Friend:
Answers
108
Questions
0
Helped
38522
Points
322
There is no factory settings for windows. You can restore the system to it`s old position from "system recovery"
Returning tablet. How do I erase everything and restore factory reset???
hi Deanna.
this is all i could find.
  1. Power off your Tablet.
  2. Press and hold Volume up and Power button at the same time until you boot into the Android system recovery. ...
  3. Choose Wipe data/Factory Reset with your volume keys and then press the power button to confirm.
More items...
Perform a factory reset on Android Device - VisiHow
visihow.com/Perform_a_factory_reset_on_Android_Device
How do you reset a Windows tablet?Reset from within WindowsPlug in your Surface so you don't run out of power during the refresh.Swipe in from the right edge of the screen, and select Settings > Change PC settings.Select Update and recovery > Recovery.Under Remove everything and reinstall Windows, select Get started > Next.More items...Refresh or reset Surface RT or Surface 2 - Microsoft Supporthttps://support.microsoft.com/en-us/help/.../surface-refresh-or-reset-surface-rt-or-surface...Search for: How do you reset a Windows tablet?
How do you do a hard reset on a Samsung tablet?Method 1: From StartupWith the device off, press and hold the "Volume Up", "Home", and "Power" buttons.Release the buttons when you see the recovery screen and the Samsung logo.Use the volume buttons to navigate the menu and select "wipe data / factory reset". ...On the next screen, press "Volume Up" to continue.Samsung Galaxy Tab 4: Steps For Hard Reset - Technipageshttps://www.technipages.com/galaxy-tab-4-hard-resetSearch for: How do you do a hard reset on a Samsung tablet?
How do you restore a Galaxy tablet to factory settings?In fact, consider finding support before you start the following process:Start the Settings app, found in the Apps Menu.Choose Privacy.Choose Factory Data Reset.Touch the Reset Tablet button.Touch the Erase Everything button to confirm. All the information you've set or stored on the Samsung Galaxy Tab is purged.How to Reset the Samsung Galaxy Tab to Factory Settings - dummieswww.dummies.com/...galaxy.../how-to-reset-the-samsung-galaxy-tab-to-factory-settings/Search for: How do you restore a Galaxy tablet to factory settings?
if none of the above work go to this link might help you out more.
tablet factory reset Google Search
2answers
How do I reset my ipad
1. Plug iPad into the computer with the USB cable. The iTunes on your computer will automatically launch. If not, double-click the icon to start it.
2. Click the name of your iPad at the upper right corner of iTunes, and then the information of your iPad will be shown. Click the "Restore iPad" button in the window to start.
3. iTunes will ask whether you want to back up iPad before restoring. You'd better choose "Yes" for the reset will erase the contents in your device. Then iTunes will start restoring your iPad to factory settings.
4. Click Restore again to confirm. Then iTunes erases your iPad and installs the latest iOS software. After you restore your iPad to factory settings, it will restart. Now you can set it up as new.
http://www.leawo.org/tutorial/how-to-restore-iphone-6-plus-to-factory-settings.html
2answers
I don't know my password to Ipad need to hard reset
iTunes enables you to restore iPad to factory settings. Before you start restoring iPad to factory settings, please note that you need to install the latest version of iTunes on your computer. Then go to Settings > iCloud to turn off Find My iPhone. Now, you can factory reset your iPad with iTunes as follows.
3. iTunes will ask whether you want to back up iPad before restoring. You'd better choose "Yes" for the reset will erase the contents in your iPad. Then iTunes will start restoring your iPad to factory settings.
4. Click Restore again to confirm. Then iTunes erases your iPad and installs the latest iOS software. After you restore tablet to factory settings, it will restart. Now you can set it up as new.
How to Restore iPhone 6 Plus to Factory Settings
To reset my ipad from apple
iTunes enables you to restore iPad to factory settings. Before restoring, please note that you need to install the latest version of iTunes on your PC or MAC. Then go to Settings > iCloud to turn off Find My iPhone. Now, you can factory reset your iPad with iTunes as follows.
2. Click the name of your iPad at the upper right corner of iTunes, and then the information of your iPad will be shown. Click the "Restore iPhone" button in the window to start.
3. iTunes will ask whether you want to back up iPad before restoring. You'd better choose "Yes" for the reset will erase the contents in your iPad. Then iTunes will start restoring your tablet to factory settings.
My iPad is disabled,how can I reset.
iTunes enables you to restore iPad to factory settings. Before you start restoring iPad to factory settings, please note that you need to install the latest version of iTunes on your PC or MAC. Then go to Settings > iCloud to turn off Find My iPhone. Now, you can factory reset your iPad with iTunes as follows.
How do I do a factory recovery on my mini ipad
iTunes enables you to restore iPad mini to factory settings. Before you start restoring iPad to factory settings, please note that you need to install the latest version of iTunes on your Windows computer or MAC. Then go to Settings > iCloud to turn off Find My iPhone. Now, you can factory reset your iPad with iTunes as follows.
4. Click Restore again to confirm. Then iTunes erases your iPad and installs the latest iOS software. After you restore your device to factory settings, it will restart. Now you can set it up as new.
3answers
How do i restore my asus b121 to factory settings
  • Restart your ASUS laptop and press the "F9" key while the computer is booting up. This will open the boot screen. Select "Recover Windows to Entire HD" and press "Enter."
  • Press "Y" three times when asked if you are sure that you want to restore. The laptop will restore the factory settings. The computer will then shut down and start up again.
  • Approve the license agreement, then select your "Language preference." Enter your name into the box and click "Next."
  • Enter your password twice on the next screen and select "Next." Enter the time zone and date information, then select "Next." Select "Finish" on the next screen and the computer will reboot.
  • Read more : http://www.ehow.com/how_6960619_restore-asus-laptop-factory-settings.html
    Nothing happens when I press F9 to try to get to system restore on Asus N53SV
    http://smallbusiness.chron.com/restore-asus-laptop-factory-settings-53444.html
    check see if you followed the steps outlined in link above
    maybe you could do a windows 7 restore
    https://neosmart.net/wiki/restore-to-factory-settings/
    A reload to factory settings is an extreme action !
    1helpful
    I am trying to restore my Acer Aspire One D255E to Factory Defaults but the restore is stalling at "Installing Cleanup" phase, it has been on this phase for over 8 hours. What should I do?
    First of all, the other people apparently don't read before they post.
    The Acer Aspire D255E has NO CD ROM, thus no restore disks, etc.
    There is a factory restore option, but I'm having the same problem, the restore option simply does not work. These crappy computers keep a spare partition hidden on the hard drive, which contains all the data needed for the factory restore. However, if something happens to this partition or this data (say it's accidentally formatted), then the factory restore will fail, having lost the backup.
    I've tried using Win XP on a flash drive using WinToFlash to copy the windows cd to a flash drive and make it bootable. However, I think my win xp version is a win98 upgrade, and so my next step is to make a bootable win98 flash drive. I'm about to try that and hope for the best.
    If you've got windows 7 (which the Aspire One normally comes with),
    then you should have much less trouble getting this step to work.
    As a side note, if you have a BIOS password you need to break, do the following:
    1. Unplug the AC cord and the battery.
    2. Hold down FUNC and ESC and don't let up.
    3. Plug in a flash drive containing the Acer One BIOS
    (which you should find easily on the web).
    4. Plug in the AC cord (still holding down those 2 keys)
    5. Turn on the power, and wait. The flash drive may light up for a moment, and the laptop may seem to be doing nothing, but it is!
    Keep holding down FUNC and ESC, maybe 2 minutes, then the Aspire One will power itself off. At this point, the BIOS is reinstalled, and the password is gone.
    How do i restore to factory without any restore diskson a lifebook t4010"
    It is not possible to restore to factory setting without the accompanying restore disks. You can attempt to contact Fujitsu Siemens and obtain a set of repair disks from them.
    Your only other option is to obtain a retail copy of Windows and perform a new installation, then download the required drivers from the Fujitsu Siemens web site.
    Top Toshiba Tablets & eReaders Experts
    k24674
    ExpressFiX
    ExpressFiX
    Grand Canyon Tech
    Grand Canyon Tech
    Are you a Toshiba Tablet and eReader Expert? Answer questions, earn points and help others
