Remove the wireless profiles on the PC and see if that helps - [b]Wireless Profiles
- Vista/windows 7
- delete the wireless profiles
Start
control Panel
classic view
network and sharing center
manage wireless networks
Delete the profiles
you will then have to enter the wireless security key for any networks you connect to
Yes, firewall can block - and often some years later for no apparent reason, if the subscription has run out it can cause issue.
turn the firewall off, what is the firewall
to check if the adapter is working OK
If you cannot access the internet with this PC, then you will need to copy the program across to the faulty PC
http://www.xirrus.com/library/wifitools....
Then run the program
if you get an error - You need [URL="http://www.microsoft.com/downloads/details.aspx?FamilyId=333325FD-AE52-4E35-B531-508D977D32A6&displaylang=en"]NET Framework[/URL] installed for the WiFi Inspector to function.
removed and re-added profile earlier with the wep key. No change. I am completely stumped.
Etaf,thanks for your help. Could hit have anything to do with my firewall setting?
