Every time i will send music or photos using the bluetooth it will not work. it says bluetooth active error. and i cannot also access email using my mobile phone..pls help me on how to activate them so i can able to send my data.
The most effective way is to use ApowerManager, which is a professional program for you to transfer photos, music, contacts, and so on between iOS/Android devices and PCs. It enable your to connect via WiFi and USB, so I think it can help you. Apowersoft Phone Manager Manage Backup Restore iOS and Android Data
Hello there,
You can send the photo via bluetooth provided the person you are trying to send it to is close to you. All you need to do is to turn on the bluetooth of the phone and turn on the bluetooth on the receivers phone, then you select the photo you want to send, then you select the options and select send, it will ask how you want to send it, select via bluetooth, then it will search for the xevice you are trying to send it to, then the mobile you want to send it to will be visible on your bluetooth list, then you select it and send the photo, it will load a page and send the picture for you.
You can also send the picture using mms, that way you will have to set the configuration settings on your phone to do so.
You need to have the internet and mms configuration settings of your phone before you will be able to send or receive any mms.
Contact the customer care of the sim service provider so as to know the settings, they can configure it for you automatically, of give you a manual settings information also, they can give you a short code that will give you easy activation access.
To send photos you need to have MMS (Multimedia Messaging Service) activated on your phone and airtime contract. If you want to send the photo via email then you need to have a data service active on your contract and on your handset.
Check with your network provider: if MMS is included in your airtime contract then they will send the correct settings to your phone. They can also tell you whether you have a data service included and also send the correct settings for that service to your handset.
Your phone is very basic and lacks BlueTooth, so if you just want to send photos to a printer or to a nearby friend's phone, you cannot use that method.
You could either use the bluetooth or the email or the mms if the size is correct for the mms.
For bluetooth, you both must have the BT started. Search for your friend's phone and have its name in your phone. Then go to the photo and from options select send. It will ask you how. Select BT and then it will show you your friends phone name. select and you photo will commence going to the other phone.
For email, you send an email with the photo as attachment to your friend. The friend can receive the email of the other phone and download the attachment.
MMS is an expensive proposition and also it has a size restriction. So it does not suit us.
Best option is the BT.
in LG type phones, this actually easy.. first the easy part is to activate your bluetooth. check also your settings and your bluetooth name for you to know your device. if it is a phone to phone transmission, both must be activated. choose the picture but notice a bluetooth symbol on top of your screen usually beside the clock should be activated or moving. go to options then choose send.. there will be choices like infrared, bluetooth, etc. of course, choose bluetooth. it will re access and prompt the you and the receiver the bluetooth detected. then done.
U can transfer those photos using email service in your phone if it's active. just send it to ur active email address and instantly u can transfer or download the attachments (photos) in your email address. If like fast transfer, u can use Bluetooth dongle or BluetoothUSB dongle or infrared service that is compatible to your phone. The 3rd option is using a USB Data Cable compatible to your phone. But I recommend BluetoothUSB Dongle cause it is easier to use,fast file transfer,less complicated and is cheaper but effective and accurate. I can provide u the way on how to use the devices i've mention if you need it. Rate my solution according to the benefit u acquire from it...TNX. Enjoy transferring.
HI This phone had a lot of issues since I have owned one and just replaced another one. You probably need to open the case and check the camera connector and also other connection. The cable or camera unit may failed. Send me an email to [email protected], I will send you a copy of service manual for this phone so you can troubleshoot it by using the instruction in this manual. Good Luck
if you bluetooth it its free
to send it as a message it's not
when sending a pic it must be sent as an mms
so follow the same procedure as sending a txt but select mms instead.
then insert or add pic to the message and send to your email address.
if this is not working you may need to contact your provider to activate mms on your service.
AGAIN Bluetooth is easier
