SOURCE: forgot my unlock code on my verizon phone and i
the default is always one of these code try them all the last four digits of the phonenumber last programmed in the phone aka your number or 9999,1234,4321,0000,1111 if none of those work you can go the retail store for a flash they hook it to the computer and push software to the phone to correct the issue it takes five mins and its free its a common issue for them to correct if you change your lock code from the default in the future always set up a dummy contact with it in there so that you can easily look it up
SOURCE: Need unlock code for Verizon Wireless Motorola V325i
Dial *228, then when prompted to do so by the automated system, press 1. After it says: "Your phone has been programmed successfully", press "OK" or "Done". When you press that, the phone will automatically power off, then back on. Once the phone has powered back on, the unlock code will now be the last four digits of the phone number.
SOURCE: How to unlock verizone wireless motorola phone?
Depending on the carrier you want to go with? If the phone doesnt have a serial # tied to verizon you can change to US Cellular or Cricket or Alltell. Well Alltell is verizon now but you get the idea. The only part that might be a little tough is if you want the phones software to look like Cricket etc. Doable but kind of hard of you have never tried it
