Bebecar M City Stroller Logo
Posted on Mar 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I bought a bebecar 3 Wheel City Racer 4 years ago. When I bought it, it came with standard wheels which I was told I could come back & order air tyres for it. Then 1 year on I went back to the shop & the owner told me Bebecar had stoped making the 3 Wheel City Racer. I am so pleased with this product & would highly recommend Bebecar to people in the future. So my question is if there is any where I could buy air tyres for this product
Anonymous
Level 2:
Scholar:
  • Expert 91 Answers
  • Posted on Mar 23, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
91
Questions
0
Helped
27557
Points
127
The Racer City & At are discontinued in the Uk however parts for the Racer is still available. If your local retailer is unable to assist you, you can purchase these spares direct by contacting Bebecar customer service on 01692 408807 Monday-Friday between 09:00-17:00. Alternatively you can email [email protected]
I have a bebecar ip op and i want to know how to detach the rear wheel as it has a puncture?
The rear wheel is held in place by a locking clip which is controlled by a lever. To remove the wheel, simply press the lever rearwards, and pull the wheel away from the housing. Remove the tyre carefully, using appropriate tyre levers, in order to repair the puncture in the inner-tube, or to replace it.
1helpful
2answers
The front wheel shaking if i go faster than a very slow walking speed. Apparently it needs to be locked in order for it not to shake. And i found a small ball from the bearing i think.
The lock for the front wheel is a little plastic clip that should be just above the wheel itself if you push that down it should stop it from shaking
Hope this helps
1helpful
Hi have a bebecar travel city but dont know how to fold it down.help
To fold down a Tracker City, firstly make sure that the front wheels are locked into fixed, non-steering mode, and that the adjustable-height handle is in one of the middle positions.
Look at the twist-grip in the middle of the handle. Press the button and simultaneously twist the collar in the direction of the arrow. The chair should begin to close at this point.
Next, find the secondary lock device, which is operated by means of a lever/tab on one side of the handle. Pull this upwards, tilt the chair forwards and continue the closing action until it is fully closed.
Align the front wheel using your foot, if necessary, to prevent the rear wheel from hitting it. To store the chair, fold down the height-adjustable handle.
Don't forget to keep the pushchair well lubricated, preferably using a silicone spray.
Why not ask [email protected] for a user-guide for the Tracker City?
1helpful
What are the dimensions of the bebecar m city?
The details are as follows ;-
1. Chassis folded size - 36.6 in X 20.5 in X 8.7 in
(93cm X52cm X 22cm)
2. Chassis weight - 25 lbs (11.4 Kg)
3. Carrycot weight - 15 lbs (7 Kg)
4. Seat weight - 13 lbs (6 Kg)
5. Seat width - 13.4 in (34 cm)
6. Handle height - 37-42.9 in
7. Wheels - Swivel
8. TSC - Yes
Good Luck!!
Thanks!!
1helpful
Have a bebecar pram-pushchair and have lost one of the protectors from the wheel. The make is bebecar grand style the wheels are 11inches or nearly 28cm. They are in blue. Every time the wheel is knocked...
The wheels on a Bebecar Grand Style are held onto the axle by means of locking clips which are, in turn, covered by hub caps. If your wheel comes loose when knocked, it sounds as though the locking clip either isn't there, or isn't clipping onto the axle properly (which can be solved by cleaning/lubricating the clip, or replacing it).
To obtain new locking clips and/or hub caps, get in touch with [email protected].
Wheels for prams
Replacement front wheels are indeed available for the Racer ST stroller. You would need to identify whether you required air-filled (AT) wheels or solid-tyre (city) wheels. Either way, pop into you local Bebecar retailer, or contact [email protected].
3helpful
Wheel problem
You need to adjust the screws on the top of the mudguard. This is mentioned in the instructions. To obtain instructions email [email protected]
Wheel clip required for front wheel of bebecar pram
You can obtain a wheel clip by going to your local retailer or bt phoning Bebecar.
3helpful
3answers
Bebecar Racer AT stroller
You just need to tighten the screws on the wheel housing around the nob that locks the wheel. This loosens up over time but I've had my stroller 4 years and have only tightened it 2 x's.
Top Bebecar Baby Gear Experts
Jennifer Rock
Jennifer Rock
ZJ Limited
ZJ Limited
john h
Are you a Bebecar Baby Gear Expert? Answer questions, earn points and help others
