You have a dead short somewhere. You need some electrical knowledge and a digital multimeter for testing. Take all the covers off. Look for wiring that has rubbed through and touching or melted. Disconnect one of the motors and replace the fuse. If it still blows, reconnect that one and disconnect the other motor. If one motor doesn't blow and the other does, you know you have a faulty motor. If neither stop the issue, then you move up to the controller and look up there. With a meter you can check for shorts within the motors, as well as grounds.
Or just take it to a Service Centre and have it repaired and serviced properly.
https://www.pridemobility.com > pdf > us_jazzy
PDF
Jet 3 Ultra www.pridemobility.com. 3 ... If the circuit trips, allow your power chair to "rest" for approximately one minute. ... thermal fuse on each lead.
INFINFB2045 Jet 3 Ultra Troubleshooting
https://www.pridemobility.com/.../troubleshooting/infinfb2045_jet_3_ultra_ troubleshooting.pdf
File Format: PDF/Adobe Acrobat troubleshooting instructions for the Jet 3 Ultra Power Chair. ... What if the systems on my Jet 3 Ultra seem to be "dead" (controller does not light up when the on/off key is ... you continually allow the battery condition meter LEDs to fall into the red area, the ... 1 Flash. The batteries need charging. Check the battery connections.
\hmm what do u need to know? how to replace battery?if so take seat off then take off shroud and u will see batterys,make a wiring diagram of how batterys are conected before u remove them, good luck
vb any battery distributor or Interstate battery outlet should have the batteries you need you will need 2 U1 batteries and they will run 175.00 to 215.00 for 2. Do not buy auto batteries and the batteries need to be sealed deep cycle batteries. Do not get at Wal Mart or any other store that wants to sell you unsealed auto batteries Hope this helps you
