Have you tried using a separate card reader to download them?
Are you sure you've saved all these photos on the inner memory card of this camera?
If you are, you do have chances to get back all your inaccessible photos from this camera.
What you should do is really simple. Just follow my steps:
Step1. Stop using this camera in case that any new file would rewrite your original photos.
Step2. Insert this camera to your computer and prepare to restore your photos.
Step3. Download a photo recovery freeware to your computer and start to retrieve all your deleted photos back:
http://www.freeware-fix.blogspot.com/2013/02/photo-recovery.html
In fact, this freeware has ever successfully saved all the inaccessible data of my friend off from his camera. So, I believe it can also work successfully on your camera memory card, too.
Simply read more information of this freeware here:
http://www.freeware-fix.blogspot.com/2013/04/data-recovery.html
Step4. Save and back up all the restored photos on a different memory card or drive in case of data recovery failure.
Note: Next time, you'd better back up all your important photos on different memory cards or drives in case of the similar data recovery problems.
This also happened to me turned out i just drank too much........ good luck........
Same problem I had once...I found this great saver of photos....it's called "Photo Rescue Advance" great little program...found my photos on the card and I was able to download them.
