I have the same problem of late. Happens with my new battery (from Samsung) and old one that still works. Am waiting for response from samsung. In the mean time my only solution is to remoce the battery and leave it for a couple of hours then the phone does boot up normally.
Sounds like you either fried your battery or killed your phone..have you taken it to the store so that they can test the battery in one of thier test phones? That would tell you if you need to replace the phone or the battery!
well u did a mistake.........u should'nt turn on the phone for a day or two............but its not a big one..........takeout the battery,remove the cover n sim........let it be off for a day or two...it should work properly if still problem exists change the battery........
If there is no other damage to your phone ie; dropped, water damage, etc, then the problem probably is the battery. If you have insurance with your current carrier, then you can get the phone replaced. This is usually a $50 deductible. Also, there is usually a 12 month Warranty Repair/Replacement option. If you purchased the phone from a retail location and still have the receipt.
hi there you can,t manually reset that now cuz' every time you power it on only logo appears, the problem for that is the program, you should have to go to your nearest sevice center to reprogram your unit. ok!
Its one of the most common problem in Samsung SGH-A707.It is mainly due to one reason i,e. your cell got wet.....!!! But you can try following steps to get rid of it:
1. Takeout the battery of your phone. 2. Leave your cell in air for a day or two without attaching battery and battery cover to it. 3. Put the battery back,it should work.If still problem exists, then I'll recommend you to buy a new battery for your cell........and before you put that new battery in your cell,leave your cell in air for another two days with the same procedure.
