Hi there, i suggest you please contact your service provider for the PUK CODE. PUK code is protect your sim card. For more details please read the below topic. Its much clear to you.
1. My phone is requesting a PIN/PIN2/PUK/PUK2 code.
Your phone is equipped with one or more codes to protect it against unauthorised use. The PIN and PUK codes actually protect the SIM card, a small card inside your phone that establishes the network connection.
In most cases, your operator or service provider is the best source of assistance with PIN and PUK codes.
Please contact your operator or service provider for assistance with your PIN and/or PUK codes. If you have already contacted your service provider and the code provided did not work, you will have to obtain a new SIM card from your operator or service provider.
^ Top
2. My phone is requesting a security code.
Your phone is equipped with one or more codes to protect it against unauthorised use. Please note that the security code, which protects the phone itself, differs from the PIN code, which protects the SIM card.
If your phone is prompting you for a security code and you have not activated one, please try the following:
If your phone still requests a security code, please bring it to the nearest Nokia care point for inspection. You can find care point addresses from the drop-down menu at the bottom of Repair.
Please note:
^ Top
3. My phone displays "SIM card rejected" or "SIM card unaccepted".
The SIM (subscriber identity module) card is a small card inside your phone that establishes a network connection. The SIM card is provided by your operator or service provider. In most cases, they are the best source of assistance with SIM card problems. Your phone may display a SIM card error message if:
If none of the situations above apply and you continue to receive this error message, your SIM card may be damaged. Please contact your operator or service provider to have the SIM card tested and/or replaced. Or alternately, bring your phone to the nearest Nokia care point for inspection. You can find Care point addresses from the drop-down menu at the bottom of Repair.
Thanks & hope its helpful for you.
PUK code
and PIN Code:
Please
dont try more than 3 times.If you try more than 3 times the Sim will get
locked.And it will ask for PIN code.Both these PUK and PIN code can be given
only by the network service provider. Please call the network service provider
of your mobile.And ask him to provide the PUK code or PIN code.He will ask you
some basic details like name,date of birth for his verification.And he
will provide you the PUK and PIN
code.This is done for free of cost.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Hi
PUK code is called as PERSONNAL UNBLOCKING KEY.
Your phone will ask for PUK code when you entered the PIN
code wrongly several times depending upon the mobile make. The mobile asks for
PUK code so that unauthorized persons do not use your mobile for wrong cause.
To get PUK code please contact your service provider
through phone or go directly to their office. They will provide you the PUK
code for your mobile. The PUK code is unique for each mobile phone model.so
that you can open your phone. When you planning to call your service provider
you cannot use your mobile as it is fully locked. Please use some other mobile
with same network to call your service provider.
This PUK
code prevents thieves from being able to
make use of stolen handsets, that is why it can only be given by the service
provider only.
While you get the PUK code ,the service provider
customer care officer will ask for your personal details to check whether the
mobile belongs to you only. If they are satisfied with your answers they will
provide with the PUK code
DONOT enter the PUK code several times wrongly,It will
block your sim card permanently.
This PUK code is FREE. You no need to pay any money to
get the PUK code
Thank You.
