My akai dlp tv turns itself off then flashes the standby light for awhile before it shuts off completely then you turn it back on only to have it do that same thing again after it was on for only 3 min. and then you do this at least 10 times before it stays on for awhile what is the problem?
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV
up(warranty was up of course) and found several bad capacitors.
Phillips and several other companies were sold capacitors that although
were highly rated failed within 5 years because of a lack of
preservatives. All sorts of electronic equipment is now being effected
due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Type in this link address, [without brackets] either to Google Search Box or into the Address Bar to your browser and press Enter. It has all the details about blinking codes of Sony Sets.
electronicshelponline(.)blogspot(.)com
In name [Electro-Help]
