Cars & Trucks Logo
Posted on Feb 16, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Tail lights and dash lights out in 96 dodge ram. all other lights work. already replaced headlight switch. still no tail lights
Adrian Fleming
Level 1:
  • Contributor 1 Answer
  • Posted on May 22, 2022
Adrian Fleming
Contributor
Level 1:
Answers
Questions
0
Helped
2806
Points
Try changing the park lamp fuse inside the driver cab fuse box
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Nov 05, 2012
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
7
Questions
Helped
16103
Points
7
Check your fuse, mine was not on the same fuse with the brake lights.
Anonymous
Level 1:
New Friend:
  • Posted on Oct 26, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
2806
Points
I have same prob on my 92 but all fuses are fine
Anonymous
Level 2:
New Friend:
  • Expert 56 Answers
  • Posted on Feb 17, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
56
Questions
Helped
17854
Points
125
Does the fuse keep blowing ?? it is also on the same line as the cigarette lighter if the fuse is blowing check that there is nothing stuck in the lighter socket that is shorting it out. Could also be a bad ground wire not makeinig contact.
Anonymous
Level 1:
New Friend:
  • Posted on May 13, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
2806
Points
I have the same problem on a 95 dodge. the fuse blows after a few seconds with the lights on. headlights work but taillights and dash do not. Where should i look for the bad ground wire. Thanks.
2helpful
2answers
1994 dodge dakota my headlights and tail lights and brake lights don't work my abs and parking brake lights are on my dash lights don't work either I replaced the headlight switch and still no
These are all different circuits. The brake lights are on a 10amp fuse - the headlights are on a 50amp fuse - and the parking and dash lights are on a 20amp fuse.
Do you have power going into the headlight switch and the brake light switch ?
97 Dodge Ram 1500 4x4: headlights and tail lights won't come on together at same time
Headlight switch is worn out, had the same thing on an old Ford pickup truck.
2001 dodge ram 3500 no dashboard, running lights, backup or tail lights
Check the headlight switch. The power goes from the fuse to the headlight switch and then to the dash and running lights.
3answers
2002 neon no dash lights or tail lights. does have headlights and turn signals. the brake lights work also. the fuses are good.
then the problem lies near the dash because dash,tail,and license plate lights work on same circuit
5helpful
3answers
96 dodge ram 2500 tail lights and instrument panel lights quit working at the same time all other lights work help please!!!
Check your tail light fuse, on the dodge ram the dash lights and tail lights use the same fuse so if the tail light fuse blows your dash lights will go out to alert you of no tail lights.
1helpful
Dodge ram 1500 the radio and dash lights are not working
did u look at the fuses under the hood there might be one there other than that sounds like you wiring went bad or the part of your switch is bad replace the switch
No tail lights, cabover lights, or park lights
relay? or the switch it self mine had that problem but the headlights didnt work
Top Dodge Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Dodge Expert? Answer questions, earn points and help others
