You will need a 19 mm wrench to fit the nut on the bracket that the idler (tensioner) pulley is attached to. Pull the wrench clockwise to release tension just enough to change the belt then slowly let tension on the belt.The 19 mm nut is just above the bolt that holds the idler pulley bracket on to the motor .
