Dacor DCM24 Convection/Microwave Oven Logo
Posted on Jan 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is the best microwave popcorn for my dacor microwave we just got it and i thought i would try some microwave popcorn it did not work very well the turntable just keep turning but the popcorn did not pop ?
A Miller
Level 3:
  • Dacor Master 8,404 Answers
  • Posted on Jan 17, 2010
A Miller
Dacor Master
Level 3:
Answers
8404
Questions
Helped
2053335
Points
24677
Put any microwave popcorn on a up side down dish so it is about in the middle of the oven. Make sure you follow the "this side up" instruction on the bag.
I am a microwave pop corn wizzard.
Dacor DCM24S microwave not working--not heating and table not rotating
The bottom door switch or its mount is bad.
See the service manual here and a help file on door switches here.
I tried cooking with the convection function in my dacor DCM24 microwave. now the microwave function will not work. the fan comes on, but the turntable doesn't move and there is no heat.
This is almost certainly a bad secondary interlock (bottom door switch) or its mount.
See my help file on door switches here.
You can download the service manual and parts list free from our site.
You can order parts by entering the Dacor part number here.
My Dacor microwave does not pop popcorn on Sensor what is the problem
i had that problem. the solution is glass. my turntable is not glass and microwave popcorn must rest on glass to pop. just place a glass dish upside down and cook it on that.
We can't get our microwave to fully pop the bag of popcorn. If we use the popcorn button it stops before the bag even starts popping. If we preset the time, the same occurs and if we run it until its...
Always place the bag of popcorn on an upside-down paper plate.
This allows more microwaves to penetrate the bag from the bottom.
Also always place food of any kind in the microwave off-center on the tray, NOT in the middle of the tray.
Not only does it cook more evenly (think of how you stir liquid) but it also prevent the same spot from being heated repeatedly on the glass turntable, which can lead to overheating and breakage.
2answers
What is the best way to cook popcorn in this oven?
It's best to put the popcorn bag on an upside-down paper plate, and be sure it's off-center, not in the center of the turntable.
Raising the plate and keeping it slightly off center allows more even heating and also protects the glass tray from overheating repeatedly in the center, which can eventually lead to its cracking.
If it still won't cook properly, the magnetron, cooling air flow or power line voltage may be less than it should be.
11helpful
My Dacor DCM24 microwave/convection oven is brand new and won't pop popcorn--old or new, large or small bag, with twice as much time as is on the bag, power on high. Doesn't work with the popcorn button...
Are you cooking it this way, as shown in the owner's manual?
"Use an overturned 9 or 10 inch oven proof glass pie plate on top of the
turntable when popping bagged microwave popcorn.
You can also use a paper plate in a pinch, but as always, never leave a microwave unattended while it's cooking, since some paper products can have impurities which will allow overheating and possibly fire.
This is a convection oven, so it has a metal turntable tray.
Microwaves cannot penetrate the metal from below like it would on a standard microwave's glass tray, allowing for even heating.
If you've lost your owner's manual, you can get it here.
The micro wave heats but won't pop popcorn. We do more time than required but 50 - 70 % OF THE KERNELS DON'T POP.
How old is your popcorn? If it's over a year old in the pantry and not in the fridge it tends to dry out/shrible inside. Or...note that these days instructions indicate between 2 types:
regular hot air popping method and microwave friendly popcorn. You can buy hot air poppers cheaply at many resale shops.
9helpful
4answers
Dacor Microwave/Conv Oven DCM24S
Placing the bag on an inverted glass bowl or pyrex casserole dish worked!!!!!  For 2 years, I have cursed my Dacor microwave for its inability to make popcorn (burns a hole in the bag, bag stays flat, almost no kernels pop, etc...)  I read the last suggestion to use the glass plate and I am now sitting with a bowl full of perfectly popped popcorn - with only 1 kernel unpopped.  The metal tray in the microwave conducts too many waves through the bag I guess.
Thanks for the solution!
Hole in the microwave
Where exactly is the hole in the microwave?
If it's a hole in the actual metal chassis of the oven, it should not be used and you should contact Dacor customer service:
http://ww2.dacor.com/services/index.asp
Quite often this is due to grease or food particles stuck to the inside of the oven or stuck on or behind the waveguide cover.
The waveguide cover is usually about the size of a playing card and often held in place by a plastic rivet.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smmoth and clean.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart or Lowe's.
If your waveguide cover is burned, it will need to be replaced. Dacor can help you find one.
We're happy to help and we appreciate your thoughtful rating of our answer.
Top Dacor Microwave Ovens Experts
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Dacor Microwave Oven Expert? Answer questions, earn points and help others
