Nokia 5130 Cellular Phone Logo
Posted on Aug 06, 2017
Well, i dont exactly forgotten it, cause just before i sleep, i remember pinning it and it works, and then this morning as i receive some text, i was supposed to open it but i can't. it says code error, but i was sure that that was my private password... but i remember that the day before yesterday, i change my cellphone by default setting but wasn't sure if it was the one that affects my password
2answers
I can't remember my google account
Hi helen, I googled "I've forgotten my google account" and this is the link you might be looking for.... Good luck.
https://support.google.com/dartsignin/answer/114766?hl=en
Forgot pin number
If you have forgotten the PIN, select the "I forgot". This will bring you to your secret question. Use the on-screen keyboard to answer it in the empty text box. Select the "ok" to finish.
If you can't remember either the PIN or the secret answer, then the Parental Controls will have to be reset. Call Nintendo's technical support at 1-800-255-3700 for assistance. Hope this helps.
1helpful
I have forgotten my pin to unlock garmin c550. What the procedure to unlock the device?? Thanks. M.Bosdachin
If you don't remember the PIN you set, take the unit back to the location at which you set the PIN. This is your Security Location. The unit will unlock and you can reset the PIN. I hope this helps.
1helpful
3answers
Nuvi® 255W Car GPS Receiver: i have a garmin nuvi 255w and its locked and need ...
I had for 2 years a nuvi 255w and its as working real good. Until one day i tried to open it up and it ask me a code pin. Witch i dont have. Ive been the only one owner on that GPS and never put any pin code on it and now just like that it want one... Grrrr that **** me off i cant use it anymore i dont have any acess anywhere exept that pin code of 4 number,. Is this possibility of update? I dont know I am the only one in that situation?
My garmin nuvi is looked and i forgot the password kan someone help me....?
If you have forgotten the PIN, take the unit to the location at which the PIN was entered. The unit will unlock and you can change the PIN to something you will remember.
Can't remember pin for garmin nuvi 660 fm , it also won't unlock at secure location.
Either remember the PIN
OR
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If you have a Garmin Lock on your nuvi, zumo or StreetPilot c500 series and you have forgotten your 4 digit PIN number you can unlock the device by returning to your Security Location. The Security Location is the location that you set when you first enabled the Garmin Lock on your device. Returning to the Security Location will unlock your device. (Approximately 150 feet from that location)
If you have forgotten your PIN and Security Location please contact Product Support for assistance. Please note Garmin will require a copy of the receipt and there will be a charge to unlock the device as this issue is not covered by the warranty.
2helpful
2answers
Can't Recieve Text Messages
Dear,
check the message centre no. that must be available in the text message setting...
check it, if it persists then u have to reset your phone or check it to the service provider... they will solve it, if the problem belongs to them.
regards,
dont forget to rate as it will fix the issue
Forgotten code
after the pin select press am or fm. dont turn on with the power button, coz you have todo it again, and make sure yuo have to put the right pin, you have i think 4 times todo that until it locked.
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
