Answer: Telephone line noise is usually caused eitherby an attached telephone or by the telephone line acting as an antennaand picking up radio frequency interference. If you have checked all ofthe telephones and telephone line devices and the noise problem occurson all outlets and all telephones (or at least all telephones without abuilt-in filter), then we recommend one of the noise problem solverslisted below. These work by removing the unwanted frequencies. If youhave tried both a filter and a choke core without results, then theproblem may be a physical problem with the phone line wiring iteself.In this case, you would need to contact your telephone company to havethem check the wiring.
It doesn't solve the problem but will give you a hand to solve it.Hope it helps.
Helps reduce noise, static and radio interference from 3-30 MHz.
Easy to install. Plugs into modular phone line.
Helps cut RFI.
Use on phone, computer, AC, audio and coax cables.
No need to cut cables - simply wind it through the core.
No, it is not connected to ADSL nor internet connection.
do you have an internet connection on the same phone line like ADSL ? if so check your libe filter.
