This is not proven but worth trying. Get a can of "canned air" for removing dust from computers, etc at wallmart/staples whereever. Be careful because this following will get very cold and could give you frost bite. Place the straw in the spray head and turn it upside down then spray the melted aluminum foil, in 1 to 2 second bursts. Frost will appear on the melted aluminum. Keep spraying 3 to 5 times to make sure it is very cold. Then use a wooden spoon to scrape it off (you can press pretty hard without damaging the oven). The cold from the liquid air will cause one of the aluminum to contract faster than the steel and you may get it to pop apart and scrape the aluminum off. If it works a little, repeat as needed.
Good luck and please rate me.
