1990 Pontiac Grand Am Logo
Posted on Nov 02, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I replace the grill on my 1990 Pontiac Grand Am
ZJ Limited
Level 3:
  • Pontiac Master 17,989 Answers
  • Posted on Nov 02, 2009
ZJ Limited
Pontiac Master
Level 3:
Answers
17989
Questions
0
Helped
14459451
Points
60858
1989-91 GRAND AM
Fig.: When installing the grille, snap the retainer tabs into the slots in the mounting panel, inserting the bottom tabs first
To remove grille, just release the tabs and pull grille the outward. Installation is done by inserting grille and locking the retaining tabs.
  1. Unfasten the screws along the top of the grille.
  2. For Achievas, unfasten the retainers from the bottom of the grille.
  3. Pull out on the grille to release the lower tabs.
  4. Installation is the reverse of the removal procedure.
Hope helped (remember rated this help) Good luck.
What is 1990 Pontiac trouble code 65
Type: OBD 1 & your codes
OBD1 GM Code 65
2answers
Where is the oil filter located on my 1990 grand am
Alero, Grand Am 1999-2005 Repair Guide.
Fig. Fuel filter mounting location and component identification
Fig. Exploded view of the fuel filter mounting
Hope help with this (remember rated and comment this).
1helpful
How do I remove the headliner in Pontiac Grand Am 1990
remove sun visor and all trim around the headliner and the dome light and basically pull it down
2answers
Computer codes 34 & 35
You can find out at a part store by either asking somebody or looking through a Chiltons/Haynes book on your make, model, and year.
Oil pressure fuel cut off sensor
next to the oil filter in the front of the motor
Trying to locate Coolant bleed valve on 1990 Pontiac Grand Prix
should be a bleeder screw on top of the thermostat housing.
Firing order, 1990 Pontiac Grand am 2.5 l, 4 cyl
Its 1342 or 1432 To guarantee correct firing order take plugs out and place your finger/thumb over the plug hole so you can feel the compression cycle.Have some one flick the key on and off slowly .As soon as No 1 has done its compression cycle the next cylinder to compress will be in the firing order.You only need to test 2 clinders to tell you which one of the two firing orders ive given you.good luck and let me know how it goes
Top Pontiac Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Pontiac Expert? Answer questions, earn points and help others
