FrancisFrancis! X1 - Stainless Steel Espresso Machine Logo
Posted on Oct 13, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Illy manufactured francis francis
Our (illy manufactured) espresso machine is not working properly. The power switch does not turn off the machine.
  • Anonymous Mar 16, 2014
    I need a service manual that explains how to take apart an illy francis francis X7.
Cerini Coffee
Level 2:
Sergeant:
  • FrancisFrancis! Expert 223 Answers
  • Posted on Jun 03, 2015
Cerini Coffee
Level 2:
Sergeant:
Answers
223
Questions
0
Helped
165772
Points
585
Illy Francis Francis Parts.. More parts to be added soon. Keep an eye on this page.
illy Francis Francis Parts Service
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 15, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
889
Points
Brand new x8 wont work
My Illy Francis Francis X9 is leaking
The issue you are experiencing with your Illy Francis Francis X9 may be due to a malfunctioning seal or gasket.
The coffee pod holder and brew head are sealed together with a rubber gasket, which creates a tight seal to prevent leaks. If the gasket is damaged or worn, it may not create a proper seal, causing water to leak out of the machine.
I believe to troubleshoot this issue, you can try removing the coffee pod holder and inspecting the gasket for any damage or wear. If you find any issues with the gasket, you can replace it with a new one to ensure a proper seal. You can purchase replacement gaskets from Illy or from a third-party supplier.
Another possible cause of the issue could be a clogged or dirty brew head. Over time, the brew head can become clogged with coffee grounds or other debris, which can cause water to leak around the edges. To clean the brew head, you can remove it from the machine and soak it in a solution of hot water and white vinegar to remove any buildup or debris.
It's also possible that the issue is related to the machine's pump or water flow system. If the pump is not working properly, it may not be able to generate enough pressure to push water through the coffee pod. In this case, you may need to have the machine serviced by a qualified technician to diagnose and repair the issue.
Illy francis x8 service repair manual
Never found a service manual for a Francis Francis - I took mine apart by looking for bolts.
1helpful
2answers
Lost nozzle on steam wand of Francis Francis x7
I did a quick search, and unfortunately, your only realistic options are to either fabricate yourself one, or try to get one via the manufacturer.
2answers
3helpful
Francis Francis X1 Gasket broken
Hello Salmonp,
You can contact Empire Fulfillment at 877-855-4540 for all of your Francis Francis machine needs. The are the authorized service center for Illy cafe and the FF machines.
My francis and francis is leaking and the espresso
Hi
Try calling Illy at 877-469-4559. They can help you get your machine fixed.
Top FrancisFrancis! Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sulejman Sulejmani
Sulejman Sulejmani
Kolbrun...
Are you a FrancisFrancis! Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
