It turns out it has nothing to do with rear door. Something about drivers door actuator. All three switches are good. Check @ BCM (under steeering colom - 16 pin connector heading down) the pink/black wire it comes from ALL rear switches. Ohm it using the battery ground. Shouldn't have any readings when door(s) and/or window closed.
What's your question ? Tailgate ajar light lit on the instrument cluster ?
The Body Control Module (BCM) monitors the lift glass and the cargo door ajar switches. When the switch closes, the path to ground is completed, and the BCM sends a class 2 message to the instrument cluster to display the CARGO DOOR AJAR message.There are two ajar switches for the rear door ,a left an a right ,the third switch is for the lift glass ajar switch . All three of these switches splice pack SP410 At ground point G410
(Shouldn't have any readings when door(s) and/or window closed.) It's the opposite . switches are open with door closed , G410
In the Body Harness, Behind the RR quarter trim panel near the D-Pillar
It turns out it has nothing to do with rear door. Something about drivers door actuator. NO IT DOESN"T !!!!
SOURCE: door ajar warning light will not go off ...
One of the door ajar switchs in your dooors has failed.
SOURCE: Door ajar alarm stays on ...
You probably have a screw in a wire that grounds the connection turning the light on. The white wire will be the one that the screw is in. The orange wire is a 12 volt wire so it can't be shorted because of a blown fuse.
SOURCE: "REAR ACCESS OPEN" LIGHT ON INSTRUMENT PANEL
inside the doorway will be contact that must be clean and unobstructed to work. Check it and see if something got caught in it. Assuming it is not faullty, this should correct the problem. It is likely that the false sensing will keep the wiper from working since it shouldn't be on with the door open. If the sensor looks okay, you should have it tested to see if it is defective.
SOURCE: 2000 GMC Sierra passenger door won't lock
The Actuator is not functioning anymore, check to see if there is a fuse for it first. If that is ok then remove the actuator and test it outside using some wire and your car battery to see if actually moves or doesent this will tell you if you need a replacement.
For
Doors not getting open with remote or key problem,there are help
links provided below.Click the link below to go through its
procedure and troubleshoot the problem:----
drivers side front door will not open from
inside or outside?
http://technoanswers.blogspot.com/2012/01/ford-f-350-crew-cab-drivers-side-front.html
Car door will
not close?
http://howtobyme.blogspot.com/2011/11/car-door-will-not-close.html
All power door
locks not working ?
http://howtobyme.blogspot.com/2011/11/all-power-door-locks-not-working-on_14.html
Repairing car
Door lock Actuator?
http://howtobyme.blogspot.com/2011/11/repairing-car-door-lock-actuator.html
How to Access car door panel?
http://howtobyme.blogspot.com/2011/11/how-to-access-car-door-panel.html
Vehicle door panel components?
http://howtobyme.blogspot.com/2011/11/vehicle-door-panel-components.html
Truck Door will not close?
http://schematicsdiagram.blogspot.com/2011/12/ford-truck-door-will-not-close.html
Where is Cars Door control
Module located?
http://schematicsdiagram.blogspot.com/2011/12/where-is-cars-door-control-module.html
Power door locks not
working?
http://schematicsdiagram.blogspot.com/2011/12/power-door-locks-not-working.html
Door ajar light stays on?
http://technoanswers.blogspot.com/2012/01/door-ajar-light-stays-on.html
Door locks not working?
http://technoanswers.blogspot.com/2012/01/door-locks-not-working-on-ford-explorer.html
Front Door dis-assembly diagram?
http://repairhelpcenter.blogspot.in/2012/02/front-door-dis-assembly-diagram-for.html
Rear Door dis-assembly diagram?
http://repairhelpcenter.blogspot.in/2012/02/rear-door-dis-assembly-diagram-for.html
How to test Power door locks?
http://repairhelpcenter.blogspot.in/2012/02/how-to-test-power-door-locks.html
Doors will not open with
Remote?
http://schematicsdiagram.blogspot.in/2012/02/lexus-doors-will-not-open-with-remote.html
How to replace
Door Hatch ?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-hatch-on-acura-integra.html
How to remove Doors?
http://repairhelpcenter.blogspot.com/2011/11/how-to-remove-doors-on-acura-integra.html
How to Replace Doors?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-doors-on-audi-a4-and-vw.html
Remote will
not unlock Rear door?
http://schematicsdiagram.blogspot.com/2011/12/remote-will-not-unlock-rear-door-on-gmc.html
Door locks or windows not working on car?
http://schematicsdiagram.blogspot.com/2011/07/door-locks-or-windows-not-working-on.html
This will help.
Thanks.
Jaguar 2000-06 - Locks & Lock Systems
Power Door Locks - Removal & Installation
Door Lock Switch
Door Lock Diagnosis & Testing
Fig. Removing door lock actuator
Fig. Removing door lock motor-Sedan
