Expert
- Posted on Sep 22, 2009
Re: Hi i have a W910i and my phone keeps on turning off...
Its a software problem,give it to the shop.
To test:
- Press the On/Off key for a minimum of 10 seconds to turn the phone on.
- Sometimes,
you need to remove the battery to clean dust, dirt and corrosion from
the connectors on both the battery and the phone. You can clean the
connectors with a soft brush, cloth or q-tip moistened with any type of
unflavoured, colourless alcohol. Make sure the connectors of the
battery and the phone are totally dry before you put the battery back
in the phone.
- Also, check for damage to the connectors of
the phone. If you have an original Sony Ericsson battery and your phone
displays an 'alien battery' message, cleaning the battery as described
above might help you correct the problem.
- If possible,
try your phone with another battery. If the phone turns on, you might
need a new battery. Before replacing your battery, make sure your
charger works properly.
- If your phone has a memory card,
remove the memory card and try to power the phone on. If the phone
turns on, you might need a new memory card.
