Televison & Video Logo
S
Siyabonga Zulu Posted on Aug 05, 2022
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am getting error 95-102 on my Sony XDCam PDW-1500
Aron
Level 3:
Top Expert:
  • Sony Master 2,586 Answers
  • Posted on Aug 29, 2022
Aron
Sony Master
Level 3:
Top Expert:
Answers
2586
Questions
0
Helped
390325
Points
78544
The movement is not able to be detected and there is also an interference that is happening as well.
1helpful
What Drv Adj err in PDW-F800 sony
Firmware Update is needed.
FUNCTION IMPROVEMENTImprovement of Disc Servo firmware to correct "DRV ADJ err" or "DI read err" error message appearance. COMPATIBILITY INFORMATION
1.) If this model is used in combination with PDW-U1 or PDW-U2 ,upgrade XDCAM drive software to v2.3.2 or V3.1.1 or higher respectively.
2.) Windows & Mac FAM Drivers must be upgraded to V2.3.0 or higher beforehand
3.) XDCAM BROWSER must be upgraded to V1.3 beforehand.
4.) CONTENT BROWSER must be upgraded to V1.1 or above beforehand
5.) If PDW-F800, PDW-HD1500 or PDW-F1600 is used in combination with this model, it must first be upgraded to V1.71 or higher.
6.) HDCA-702 used with this model must be upgraded to V1.10 or higher.
CAUTION ABOUT UPDATE PROCEDURE
1.) Execute "All File Save" to Memory Stick before starting the upgrade,after the upgrade please execute "Factory Preset" followed by "All File Load" from MS.
2.) Be sure to use external DC Power,Battery not recommended.
3.) Implement software update without disc inserted.
4.) Set VDR power save switch to STBY position.
5.) Disconnect all I-Link and Audio cables.
6.) If the Power is turned OFF during the process,restoration of the software package will not be possible, be careful.
7.) Follow the installation instructions in the Release Notes.
https://pro.sony/qf_CA/product-resources/software-firmware/1237492951598
https://pro.sony/s3/cms-static-content/operation-manual/3297517131.pdf
Sony camcorder xdcam pdw-700 error codes 91-225
No matter what errors are present you will need the manufacturer to repair it, they do not supply repair info or parts to the public, only approved repair stations.
What is the solution to error 02-F37
No mvement is detected in the ND filter initial operation check of OP (OP0).Problem with laser.
Hi we have a PDW-HD1500 with an error message/code of Error02-FB7. Thanks.
Error code 02-FB7 means "No movement is detected in the ND filter initial operation check of OP (OP1)", meaning the filter that regulates the ammount of light coming out of the laser diode is faulty. It does not say what the problem is, only that there is one.
Swapping the OP (Optical block assembly (the laser thingy on the two rails in the ODD)) for a new one will certainly fix this problem. just make sure you don't touch the lens!
Pdw u1
This indicates the hard drive has errors from bad sectors to file corruption, the hardware should be tested, maybe possible to repair.
2answers
Hi when i put the XDcam DLA 50 GB disc in my Sony PDW 510 XDCam recorde geve code 03 - 354 error. i dont know about dat. do You can help me ? Thank
03-354
03: optical drive two-axis (FCS, TRK)
-354: No signal from disc required for OP focus servo can be detected. Disc is not rotating
I would try another disc and if you get the same error call Sony's service center.
1helpful
Error 03-454 on pdw1500 deck
What is error03-354 on my Sony XDCAM PDW-F350L?
Thank you. HELP! email: [email protected]
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
