My Hisense LED TV lost its picture, What could be the cause and how do I fix it?
I have a Hisense 55K23DGW, We were watching TV when the left ~1/3 of the screen when darker, a minute later, we heard a loud pop and lost the entire picture completely but we still had sound. What could be the reason behind the pop and loss of picture?
This model TV will have from 10 to 12 LED strips (depending on serial number) sitting vertically in the panel, you will need to replace them all to fix he set. On some brands if one lamp fails the overload circuitry will shut down the inverter section of the power supply but on most Hisense brand sets including the one you own there can be up to about half the LED buttons shorted (not lighting) and the set will continue to work with a darker than normal picture but eventually enough will burn out and the inverter will shut down from over current once the set has run for a few minutes, this is what you're experiencing. Our service center has repaired hundreds of Hisense sets where replacing backlights fixed the TV, from what I remember we have never had a power board failure causing this issue, its possible there has been as we have several service techs working on TV's but personally, I've never ran into the power board failure causing the LED lamps to not light.
Okay you have a big problem this is common with a low-grade TV like that the LED lighting in the back of the TV has gone bad and perhaps the power supply could be causing this I attached a video so you can see an example of how this is fixed it's not easy to do you might need the resources of a shop to do it in the future steer clear of non brand TVs and I say this just as a suggestion hisense tv bad leds YouTube
? 5:56
https://www.youtube.com/watch?v=xUzCLgoSPGM
Sep 15, 2014 - Uploaded by ShopJimmy.com
LED & LCD TV How to Diagnose Symptom of No Image on the ...the the tv turns on but there is no picture or sound and I can't seem to fix it the .... +tbones11234 I have the same on myHisense 55" TV,what did you ... The problem is when i turned it on it shows on the screen the sony logo three times then its ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Click Here to BUY TV REPAIR P... ... I Have a Hisense Tv in My Screen Is Not Working Right The brightness is ... Hi my TV shows the picture for a moment and then goes .... here the sounds but you cant see nothing and a sanyo flat screene.
? 5:56
LED & LCD TV How to Diagnose Symptom of No Image on the Screen CLICK HERE to BUY ... I have an LG ...
? 1:48
https://www.youtube.com/watch?v=xI3MpZukKm0
Nov 20, 2013 - Uploaded by After Hours Tv & Pc repair
Find the correct TV part for your TV and more at ShopJimmy.com Click Here: http://bit.ly/ShopJimmy6 Want to ...
I have sound and picture but no backlight. .... how do you replace the back lighting on a led lg tv? ... I have a 42 inch LED LCD combo DVD TV made by RCA.
Dec 28, 2015 - Hi, I have an RCA 32" LED 1080p TV that is less than 2 years old, and it has already lost the video. I can hear sound, and I can see lights in the ...
? 4:04
https://www.youtube.com/watch?v=KWIWeESmXC0
Aug 10, 2014 - Uploaded by Tampatec
Common easy lcd tv service repair fix, TV's distorted rainbowpicture screen fixed by ... Common easy LCD TV fix: bad picture screen rainbow colors ... Need to report the video? ... Sanyo LCD with Distorted Half Picture Lines Waves Distortion Distorted ...Duration: 11:36. by Do It With Dave 316,733 views.
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Mar 1, 2011 - Uploaded by Grants Pass TV Repair
With LCD TVs you can have the same display problems fordifferent ... Fix for Samsung lcd TV colour display problem - Duration: 1:26. by alwaysafix 462,823 views. 1:26. Sanyo LCD with Distorted Half Picture Lines Waves Distortion ... HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ...
