1-check condition of CD 2-be sure fairing brackets on bike are not broken 3-be sure riser bolts are not making contact with the bottom of the radio
if all of the above are OK, it's either a defective CD drive or bad SDRAM circuit (40 second buffer memory). The unit will need to be repaired. For repair options, contact Iron Cross Audio. www.ironcrossaudio.com
you may possibly need a radio update here is the website that has all of the instructions as well as the download to attempt to repair. you will need a blank recordable cd http://www.harley-davidson.com/en_US/Content/Pages/Genuine_Motor_Accessories/advanced-audio-system.html
The 23 pin main connector is a direct plug in from the 03 bike to the HK unit. The only issue would be if the original 03 was using the accessory connector as well. The accessory connector on the 03 is another 23 pin. It's a 35 pin on the HK. For more info, or to discuss this further, contact Iron Cross Audio (www.ironcrossaudio.com)
06 units did not have the audio circuit vibration mod installed. Unit needs to go under a microscope to isolate the bad component or solder joint. www.ironcrossaudio.com can help with the repair.
