SOURCE: Getting sam4s out of closed mode
My last day of menstruation was March 16, 2009
and I checked thru pregnancy test; there are two lines although the 2nd line was not as visible than the first, am i pregnant? If yes, when did i concieved, what date? Thank you
SOURCE: SAMSUNG ER-5115 SAM4S CASH REGISTER LOCK-UP
Turn off the machine. Hold down the lower right key on keyboard. Turn key to P. Turn on machine. That should clear it out. It will also log you off you will need to log back in. Make sure you correct your mistake
SOURCE: I need to re-program the text at the top of my receipts. Any help?
look in manual for the register
SOURCE: my sam4s er-180t casg register now states its closed !! what doi do
Hi Clare,
I don't know if you have fixed the issue yet but I am going to respond anyways :). It appears you have accidently pulled yourself out of clerk mode by pressing "0" then "clerk". When you do this, you are telling the register that you have no cashier's using the register, so it will lock the cash drawer in place. To remove the close and continue ringing as an active register, you have to press the number "1" button, then the "clerk" button. This will allow you to use the register again. You can also assign multiple clerks so that you may pull individual reports if for some reason you have multiple people using the register. You just have to make sure when you do this that you hit "0", then "Clerk" first, then you can log in as Clerk 2, Clerk 3.....etc. etc. Clerk 1 will be your primary clerk and it's the clerk assigned when you first received the register.
I hope this helped. Sorry if I was a little late. I have been traveling and have not had the time to really sit down and write this out. If you have any other questions regarding this register model please let me know. I have kind of become an expert on them having used them for the last three years.
Good luck and hope this works for you.
Scott
SOURCE: my sam4s er-180t cash register wont respond it just beeps and comes up with E00
When it beeps as you like that it could be for multiple reasons. Which mode do you have the key set to? Is it X? Z? Are you in Register mode? (REG). When you press the "CLEAR" button, this beeping should go away. You can then address the problem by elimination. Perhaps there is a transaction still in progress but you have tried to pull reports or have done something else. The register is going to continue beeping at you until it's cleared. (Cancel transaction or finish ringing it up).
