SOURCE: Casio qt-6600 Order receipts sizing
U mean the paper size? the QT-6600 is a rom based terminal, paper size is depend on the receipt printer u attached with.
If u mean the wording, u may change it in PGM2, by pressing the "DBL" key when u input the word.
SOURCE: qt-6600 order receipt
http://www.casiohelp.com/products/index.php?main_page=product_info&cPath=16&products_id=17
SOURCE: Casio QT-6600: How to assign PLU to menu key ?
This is done in P3 and if it needs to be put in a menu it will have to be done in the pulldown groups.
SOURCE: SOUND VOLUME CASIO QT-6600
if your computer came with a motherboard disc the sound drivers could be on it have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
don
SOURCE: HI I WANT CHANGE name and tlf number on casio QT-2100
Hi. Casio don't give out programming information for the high end terminals. You need to purchase a separate programming manual for this model. You can find it on the net. It has the codes and tables for changing characters on the receipt. try this link:
https://the-checkout-tech.com/manuals/cashregisters/Casio_QT-2100_programming_manual.html
