SOURCE: handset
Presume you are talking about the extra handset. Try placing the extra handset in the "main" base for 5 seconds.
SOURCE: My handset reads Low Battery Charge Handset and i
Well.. You may not like my solution.. because I had the same problem with the same phone as you have and everything I did was not successful. WHY you ask??
Because it sounds to me that the rechargable battery itself is either defective, worn out \Or maybe the phone was dropped causing the battery damage, due to the sudden jolt when it hit the floor, as these rechargable batteries are not indistructable??)
I bet if you go toUNIDEN site or the electronic store and replace the rechargable battery, with a BT800/BP800 Battery Pack as what I had to get (but check make/model of the battery pack you already have installed in handset), your phone will continue to operate as if it was new again. I paid about $30- for my battery pack.
SOURCE: mobile l-7 is not charging
your problem is known already,since the battery charge in another phone.
All you need to do is just to replace the charging port because from all indication your charging port is bad.
If you are able to replace the charging port, your phone will charge.
Take care.
