Computers & Internet Logo
P
Paul Patterson Posted on Nov 07, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to fix not rewind craftsman posilock tape 12 ft x 1/2 in 39406?
Item 39406
Dolf
Level 2:
Habit-Forming:
New Friend:
  • Expert 46 Answers
  • Posted on Nov 07, 2019
Dolf
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
46
Questions
0
Helped
10683
Points
110
Step 1 - Open the Case Use a small screwdriver to open the case. Be careful with the contents inside after the case is open, as you do not want the tape and the system to fall out of the case and unwind. To prevent this, keep your finger on top or use a small piece of masking tape to keep everything in place.
Step 2 - Look Inside Take a look inside the case to see if there is a simple problem with the retraction system. For example, the spring might be undamaged but unhinged from the tape, or there might be dirt clogging the spring. If it's an easy fix, remove the dirt or reinsert the spring, and then proceed to the sixth step to close the case.
Step 3 - Remove the Tape If the problem runs deeper than a bit of debris, you will have to remove the tape to observe the retraction system. Take the tape slowly out of the case, holding the retraction system in place. Once the tape is completely out, disconnect it from the spring.
Step 4 - Replace or Fix the Retraction System If the spring is broken, disconnected, or damaged, you will need to replace it with a new one. You can purchase a new part at the same store you bought your tape measure from. Make sure you have the model number and size when you go to the store to get the exact fit.
Step 5 - Put the Tape Back After replacing the spring, connect the tape to the spring by putting the end of the spring into the hole at the start of the tape. There is usually a part connected with tape. Use some masking tape to put it back together. After you've secured the connection, let the tape roll slowly back into the case.
Step 6 - Close the Case Having tested the retraction system by letting the tape roll in, you have successfully repaired your retraction system. Now, remove the masking tape keeping the system inside the case, and reattach the top cover with the screwdriver. Your measuring tape should retract again properly.
If, after completing this guide, your tape measure still doesn't work properly, consider purchasing a new one or upgrading to a laser tape measure for reading at a distance.
3 Related Answers
Anonymous
  • 254 Answers
  • Posted on Jul 10, 2007
SOURCE: VCR eats tape when rewinding
A couple of possibilities: 1. Braking problems: When VCR goes from FFWD, REW, Play to stop, there are a pair of "brake pads" engaged to stop the reels, and prevent tape spillage out into the machine. These pads, often rubber like, are on levers which contact one side of each reel. If you take the cover off the VCR, and look down where the tape is loaded, you will like see these brake assemblies. If the rubber pad is missing, or lever pivot points gummied up, then this is your issue. 2. Take up reel isn't being engaged to take up the tape on tape eject. When a tape is loaded into the machine, tape is pulled from the cartridge and threaded into play ready position. When eject mode is engaged, the tape must be pulled back into the cartridge, or you will have tape hanging out the front end of the cartridge, and may get caught on the VCR internals, or at least be mangled by the cartridge door. The often issue here is likely the idler assembly pivot point is sticky. This idler pivots, moving from the take-up reel (right reel) to the supply reel reel (left one), depending on what mode is selected. FFWD & play to the right, left for REW. If this idler is gummed up at it's pivot point, movement will be sluggish at best, and might not be engaging the right reel quickly enough to pull tape in before tape eject. This idler is sitting right between the reels down where the tape sits. A little light oil on the pivot point may be enough to loosen it up. Otherwise it might need to be removed and the old grease removed, and a drop or two of light oil applied.
Anonymous
  • 61 Answers
  • Posted on Nov 12, 2008
SOURCE: 8mm Tape stops when rewinding
try this:
some cameras have a memory where they begin make sure the memory is off or cleared then try to rewind or try fwd to end clear memory then rewind tape...
now sometime tapes of 120 are really not recommended because of the load of tape amd ost have a tension sensor 60m is usually the best recommended
Anonymous
  • Posted on Oct 17, 2009
SOURCE: how to fix a stanley power-lock 25 ft measuring tape
Take the four corner screws out and the last center (short screw out). Split the shells in two pieces. Seperate the yellow or measureing tape from the black spindle tape. The spindle tape holds or attaches the measurement tap to the spindle. I have only seen a plastic spindle and this tutorial only applies to the plastic one. Take the spindle out and set the half casings on their backs, so you can see the cavity of the shells. The black spindle tape will be preformed to only wrap one way. Go ahead and attach the yello measuring tape to the black spindle tape. Pay close attention which side of the yellow tape is facing up or in our intended direction which is towards the center of the spindle. This way when you pull the tape out it is facing up for the person can see the measure marks. Wrap the tape tightly. If the tabs are broke and there's no way to secure the Yellow to the black, use two strips of Duct Tape and adhere the sections together. Do not use too much tape, since the clearance inside the spindle is tight. Once you wrap the tape inside, put a temporary piece of tape to secure the yellow and keep it from unraveling again. Next take a 1" wood screw and a battery powered drill and insert the screw into the center of the plastic spindle. Slowly tap the screw until it catches, do not drill the screw all the way in, only enough to catch in the plastic. Once the screw is partly into the plastic place the spindle into one of the half shells. The reason for the drill and screw is to return the tension back to the internal spring. Whichever side you placed the screw into you need to be sure to apply a clockwise turn. Keep the hex head of the drill so to not release the tension. At the same time place the spindle in the half shell and lock its square center piece into the shell. Now you can remove the screw from the center, then remove the tape holding the yellow meauring tape down, Still holding the measuring tape so it wont unravel, begin placing the last half shell on. Obviously you need to line everything up so the tape slides freely through its opening. Align the tape slide stop, which rests between the two shell halves. Replace the screws and remember the short one goes in the middle and holds down the belt clip.
Frank
Camcorder VHS tape is tangled
cut the tape that tangled area and rejoin with sellotape.
Or
Chane the recorder playerhttps://www.google.co.jp/search?q=sellotape&newwindow=1&tbm=isch&tbo=u&source=univ&sa=X&ei=0QNUVaiFAcGOmwXF7oG4BQ&ved=0CC8QsAQ&biw=1920&bih=979#imgrc=WlW70BWBCqz_qM%253A%3BG8Oz9CELNuC-3M%3Bhttp%253A%252F%252Fwww.londongraphics.co.uk%252Fnetalogue%252Fzoom%252Fsellotape_original_adhesive_tapes.jpg%3Bhttp%253A%252F%252Fwww.londongraphics.co.uk%252Fproducts%252FGraphic-Supplies%252FAdhesives-Cutting%252FAdhesive-Tapes%252FSellotape%252F293528_Sellotape-Original-Tape-18mm-x-66m%3B600%3B600
2helpful
The pull cord on my Craftsman gas blower model 358.794765 was jammed with about 6" sticking out. I took it apart and found nothing broken but now i cannot figure out how to put the spring in. There does...
Most likely the reason for the jamming of pull rope would be the rewind coil was over stressed due to use and age (they become brittle after a while) and where the coil catches on inside of housing snapped causing a slight unwinding and then the restricted movement of pull rope assembly. If you have it apart you should be able to see where the coil connects at both ends and attaches to its mating location. If you do not see the typical bent coil hook then your coil is broken. No worries, if this is the case, heat the broken end with a lighter or torch and use a pair of needle nose pliers and reshape to match the hooking location. Once completed, rewind coil and place masking tape around coil temporarily holding coil in place and leave yourself about three inch lead of coil to attach where it needs to go. Insert and fasten coil assembly then remove all pieces of tape. At this time your pull rope should be recoiling and rewinding pull rope. Always wear eye protection.
1helpful
My VHS tape does not rewind all the way to the
hit rewind again. does this happen to both sides?
2helpful
Loads tape then stops - won't play rewind fast
Way to go. Usually if you use anisotropic Alcohol with a few Q-tips works well I've found.
Try cleaning the other tap path items like the capstan that the pinch roller get's pushed up to also with this Alcohol. The cleaner the better the tape goes through. Much better picture.
Blessings,
A/V Media Guy
Air pressure gauge does not move on Craftsman 1Hp, 12 Gal. Air Co
I would say that the gauge needs to be replaced. These are common items so go to any auto parts or craftsman hardware store and purchase a replacement.
be sure to use some joint compound or teflon tape on the threads so u dont have any leaks.
please rate my answer. thanks.
GE VG4056 will not rewind
The photo sensor that senses the tape end has blown or dry soldered.It is on the right side of the mechanical deck and senses the transparent end of the tape through the square hole in the video cassette.
2answers
Sharp VCR Model VC-685U
Actually the problem is in the capstan drive. If you replace or clean the idler, the problem will likely disappear....accordianman
2answers
VHS tape was playing . After stoping does not play. Other tape will play
The idler wheel (that only drives the tape in play or scan modes) is slipping too much (very common problem). Try verify this by putting the tape in play then immediately press the fast fwd or rewind buttons to scan the tape. On older machines, the idlers used rubber friction tires - on newer ones, a clutch. Either replace the tire or increase the spring tension on the clutch.
Hope Ya Fix It.
try this:
Top Craftsman Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Craftsman Computer and Internet Expert? Answer questions, earn points and help others
