I couldn't find a manual for this oldie, but here's programming guidance from Uniden:
Here are basic instructions for programming nearly all of the older scanners that Uniden produced.
When the scanner is turned on press the MANUAL key, then press the
channel number that you want to program first, then the MANUAL key
again. This will stop the scanner from scanning and hold it on the
channel that you want to program.
Then you enter the frequency (be sure to use the decimal point
in the right area when entering in the frequency) and then press the E
or ENTER button to save the frequency on the channel. You are now
finished programming the channel. To advance to the next channel simply
press the MANUAL key and enter your next frequency the same way that
you entered it on the previous channel (as described at the beginning
of this paragraph).
I hope this helps.
