HP L1955 monitor manual
I hope this link helps... Good luck!
http://bizsupport1.austin.hp.com/bc/docs/support/SupportManual/c00283625/c00283625.pdf
Testimonial: "Wow! That was quick and found exactly what I was looking for. Thanks!"
Try This:
Manual HP L1955
Good luck
SOURCE: How do I remove the bezel from my hp l1955 monitor
There usually screws hidden behind stick-on plastic covers on the front and or edges of the screen. Use a sharp point to lift off these covers to reveal the screws.
The bezel will also have plastic catches/clips that secures the bezel to the lid as well as double sided tape. Slip a thin blade between the glass screen and bezel and gently lift the bezel free. Start at a corner and gradually work along each side.
Be careful not the apply too much pressure on the glass (it is easily cracked) and be careful not to scratch the screen.
SOURCE: I have several HP L1955 and L1925 monitors do not show image
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
